rear suspension
Old Oct 2, 2006 | 12:41 AM
nfo184's Avatar
rear suspension
how do i tighten it up? i have the rear strut brace from stillen and the front from dc sports on back order, but should I upgrade the stock sway bars??? also how do I remove the rear shocks.....I cant see the tower bolts in the trunk...is it under the seat???? and is tein s tech or h tech better for the 04 g35 6speed with 18's but i'm getting 19's
Old Oct 2, 2006 | 11:10 AM
cato's Avatar
SouthernComfort Moderator
Sway bar upgrade is very popular and makes a big difference!
Old Oct 2, 2006 | 02:19 PM
kenchan's Avatar
the top mounts for the shocks are bolted upwards from the wheelwells.
i recommend the front/rear swaybars. don't do the G35C S-techs for sure.
the rear rate is too soft.
Old Oct 2, 2006 | 02:31 PM
zackt69's Avatar
rarejdm.com
+1 on the sways... really tightens the whole car up
Old Oct 2, 2006 | 09:54 PM
nfo184's Avatar
what about the h tech springs then?
Old Oct 2, 2006 | 10:00 PM
Calvin's Avatar
Overglorified Altima
^^g35 h techs will barely drop you. 350z h techs
Old Oct 3, 2006 | 06:50 PM
nfo184's Avatar
or should i get the 350z s tech??? is it a better spring rate than the g35 s techs?
Old Oct 3, 2006 | 07:35 PM
johnbigbootie's Avatar
From the sticky:
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Stiffer then oem by F+23% R+16% (see note at very top)
Tein S-tech G35 coupe & sedan (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Stiffer or softer then oem springs by R+14% R-18% (see note at very top)
So, G35 S-Techs have rear spring rates 18% softer than OEM, 350Z S-Techs have spring rates 16% firmer than OEM. Fronts are a little firmer, too.
Old Oct 3, 2006 | 08:11 PM
Calvin's Avatar
how much of a drop do you want?
Old Oct 4, 2006 | 07:11 PM
nfo184's Avatar
i have a c/f lip kit that i dont wanna crack but I know how to avoid dips and how do drive it low..... also i dont want camber issues so i'm thinking of getting 350z h techs since there a lil lower than the g35 h techs and also stiffer......is this a good choice? or is it not that noticeable of a drop???
Old Oct 5, 2006 | 06:59 PM
nfo184's Avatar
is the 350z h techs pretty good? or lower ??? i know they settle more on a g than a z and are lower
Old Oct 5, 2006 | 07:11 PM
Calvin's Avatar
my h techs have settled more and im loving them thus far. perfect drop for me so far.
heres a pic of 350 h techs (left) vs stock springs (right)
its subtle but noticeable
Old Oct 5, 2006 | 09:56 PM
SFG356MT's Avatar
the sway bars and the 350z H-tech
Old Oct 6, 2006 | 06:53 AM
nfo184's Avatar
ok sounds great......just what i'm looking for thanks.....hows the camber??? any bad issues? or did u use the stock camber adjustment?
rezendvous420
May 31, 2020 01:26 PM
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
si_driver
Aug 11, 2015 07:08 AM
TreeFiddy
Aug 10, 2015 06:50 PM
atk08
Jul 30, 2015 03:12 PM
