SPC camber kit installed, pics, 56K no
The 03-04 service manual calls for the following specs for 17 and 18 inch wheels. I don't think it would be any different for 19's and 20's. I had my 20's aligned within these specs.
Front Camber
Minimum − 1°15′ (− 1.25°)
Nominal − 0°30′ (− 0.50°)
Maximum 0°15′ (0.25°)
Front Toe
Minimum 0 mm (0 in)
Nominal 1 mm (0.04 in)
Maximum 2 mm (0.08 in)
Rear Camber
Minimum − 1°45′(− 1.75°)
Nominal − 1°15′(− 1.25°)
Maximum − 0°45′(− 0.75°)
Rear Toe
Minimum 0 mm (0 in)
Nominal 2.8 mm (0.110 in)
Maximum 5.6 mm (0.220 in)
Front Toe
Minimum 0 mm (0 in)
Rear Camber
Rear Toe
Minimum 0 mm (0 in)
Originally Posted by Archangel
I didn't specify it, but the steering does center faster. I think they tried to get the car aligned as close to Infiniti specs as possible, but they were so giddy about the kit, they may have tweeked it a bit. I have to go back because no matter what they say, the car is still pulling to the right. I might have them dial up the caster. I've got to do some reading and refresh my memory on how to set up a suspension.
Originally Posted by _jb
I looked all over for a set of these springs. No one had any.
Where did you find them?
Your G looks great... Perfect drop...
I bought my springs from another member of this forum, but here is a link to a retailer that sells both the 350Z springs and the G35 springs:
http://www.xs-engineering.com/xsstor...ory=328&page=3
Originally Posted by aleok
Archangel- did you fix the sensor problem yet?
Unfortunately I didn't have time to look at it this weekend. It probably won't be till this coming Saturday that I have a chance to take it to the shop, and I feel a run-around coming on.
Originally Posted by Nismo G
Not sure if you know, but i know there was a TSB somewhere about 03-04 coupes pulling to the right no matter what. If you take it in they replace some part on the car....
You are very close to being within specs. You will be fine without installing the hub spacers. You are within coupe specs, but just barely.
I don't have the sedan alignment specs handy at the moment, but you should be able to find them on Driver.
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
