View Poll Results: wat problems r u having?
installed spacers, have ABS, Slip, VDC lights on
29
18.01%
installed spacers, have knocking
4.35%
installed spacers, have both lights and knocking
3.73%
didn't install spacers, have no problem
40
24.84%
didn't install spacers, have one of the problems above
4.35%
didn't install the camber kit yet.
43
26.71%
installed spacers, no problem
29
18.01%
Voters: 161. You may not vote on this poll
SPC Poll
Old Feb 4, 2007 | 10:16 PM
  #91
SuperShick's Avatar
hey guys,
i installed the SPC camber arms but i think i'm having a major issue.
i took off my aftermkt cusco a-arms and i swapped them with my SPCs. i think i'm missing a conical bushing that's supposed to cushion the joint. i don't know have OEM ones but is getting that conical bushing feasible? should i order from dealership or someone might have that extra conical bushing around? what do you guys think?
Old Feb 4, 2007 | 10:51 PM
  #92
Gilley's Avatar
You need that bushing. If you don't have your oem arms, look in the classified section.
Old Feb 4, 2007 | 10:55 PM
  #93
SuperShick's Avatar
do u think those bushings can be obtained from the dealership or only from the stock link?
Old Feb 4, 2007 | 10:58 PM
  #94
Gilley's Avatar
I have no idea. Call the dealer. 305Z bushings will work too so call Nissan. Some people sell their OEM a-arms in the marketplace.
Old Feb 4, 2007 | 11:04 PM
  #95
SuperShick's Avatar
Gilley,
you did the install. how dangerous is it to drive carefully on the roads for now? if i don't hit the bumps and what not. do i run the risk of cracking or breaking the stud off from the SPC a-arms?
Old Feb 4, 2007 | 11:15 PM
  #96
aleok's Avatar
set the red boot on the arm joint and then pull the spring towards the boot, yea.
Old Feb 5, 2007 | 02:58 AM
  #97
SuperShick's Avatar
safe to drive?
Old Feb 5, 2007 | 05:18 AM
  #98
aleok's Avatar
huh? yea its fine. the boot isn't an compression cup or anything, its just there to hold the grease in there. i remember seeing someone use an actual condom on an a-arm joint to hold grease.
Old Feb 5, 2007 | 09:29 AM
  #99
Gilley's Avatar
If you are referring to the rubber boot, you are fine to drive. If you are referring to the cone bushing, I don't know if it it is safe or not, but I wouldn't drive it.
Old Feb 6, 2007 | 12:54 PM
  #100
SuperShick's Avatar
good thing infiniti has parts for this: 16 bux per conical bushing =/
Old Feb 6, 2007 | 01:41 PM
  #101
Gilley's Avatar
That's good information to know. Post a PN and/or link if you don't mind.
Old Feb 6, 2007 | 07:04 PM
  #102
aleok's Avatar
$16 bux for one of those little things!
Old Feb 6, 2007 | 08:20 PM
  #103
SuperShick's Avatar
dude, it was murder....i'll post the P/N later tonight =)
Old Feb 8, 2007 | 03:18 AM
  #104
mark4x4's Avatar
I continued to have the knocking issue with the revised arms. SPC assumed the arms would work and had 50 arms in production. A rep from SPC and I met today and went to my installer (Auto Innovations) who also been working with SPC. Working together using a grinder and clay we could tell exactly where the arms were hitting. Bottom line is I firmly believe the next redesign will definitely work, creating a high quality arm while giving much more clearance. SPC is hoping for a time frame of 2-3 weeks for completion of the new arms.
I can truly say that SPC is working very hard to get the arms perfect and in production asap.
Mark
Old Feb 8, 2007 | 04:48 AM
  #105
aleok's Avatar
^wow, the 2nd revision didn't work, now a 3rd? haha, you would think that SPC would have done enough r&d before actually producing these, the 1st bunch and the 2nd.
