GT Spec bars-installed(rear)
Old Dec 9, 2006 | 02:41 PM
obender66's Avatar
Today I installed rear GT spec bars. Didn't do front-don't have enough leverage to crack suspension nuts.
Rear bar-the easiest-take 2 nuts off, put bar on, put nuts back on.
Lateral little more difficult, you have to mark position of toe(I guess?) adjuster-it may start rotating messing up your alignment. If it happens, just reach from another side with 19 mm wrench and turn it back to place.
It barely cleared exhaust-it will probably rub a bit, but after exhaust chews itself a gouge in bar, it will be OK. I didn't hear any banging on test drive.
My Tanabe hangers are modified to sit about 10 mm lower to clear Progress bar.
Driving impressions-I have winter tires on and they do not inspire any hard cornering. Feels a bit more composed over speed bumps and when getting on my driveway.
Tools-breaker bar, 17 mm socket, 19 mm wrench, torque wrench(setting 48-59 ft/lb on all nuts). Manual recommends replacing the nuts after each disassembly, but I didn not. I'd check all torque in a week.
[IMG][/IMG]
[IMG][/IMG]
Old Dec 12, 2006 | 01:24 PM
cato's Avatar
SouthernComfort Moderator
Lookin' good. I have the front and rear tie bars, lateral bar will not fit the sedan with coupe mid-pipe. Much better handeling with the GTSPEC bars. I wish I could do the lateral bar, but coupe mid-pipe is a must have for me.
Old Dec 12, 2006 | 08:46 PM
Alan's Avatar
awsome ive been thinking about getting these.
Old Dec 12, 2006 | 09:32 PM
redlude97's Avatar
Are you running a rear camber kit? Does the lateral bar have a elongated bolt hole to be used in conjunction with the SPC toe bolts?
Old Dec 12, 2006 | 09:49 PM
hai109's Avatar
You must live in an area that has snow...Just by looking at your under carriage...Nice pic BTW...
Old Dec 13, 2006 | 03:10 PM
obender66's Avatar
All holes are elongated on all bars. I do not have rear camber kit, so I cannot say how they would work.
Old Dec 15, 2006 | 01:21 AM
chobble19's Avatar
on another thread it was said that there was an issue with the bolts not being long enough for both?? is this true?
Old Dec 15, 2006 | 08:37 AM
QuadCam's Avatar
are these for real? I only see honda civics driving around with all these little bars under the car.
Old Dec 15, 2006 | 08:58 AM
cato's Avatar
Oh yeah they are for real. I noticed an improvement in the overall handeling after having the front and rear tie bars installed.
Old Dec 18, 2006 | 10:31 PM
partshipperdave's Avatar
nice write-up and pics. Thanks for sharing the info. Yes these chassis braces are for real, and they are a nice improvement to stiffening things up and making your car more responsive during "spirited" driving.
We are having a nice sale on these and have them in stock and ready to go for anyone interested.
I'd recommend refering to this thread for install info!
Old Jun 24, 2007 | 12:49 PM
GreenGoblin's Avatar
The goblin resurrection
i am also wondering about the toe bolts
Old Jun 24, 2007 | 07:00 PM
cloud's Avatar
+1 on the toe bolts
Th611
Oct 27, 2015 03:48 PM
derres
Aug 28, 2015 03:27 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
Soumilg
Jul 18, 2015 12:33 PM
