My SPC A-Arm installation
Old Nov 18, 2006 | 05:56 PM
  #136
aleok's Avatar
^HAHA! i just did that last week! suck yea.
Old Nov 18, 2006 | 07:30 PM
  #137
Gilley's Avatar
If you have the OEM locks, a Nissan or Infiniti dealer can take it off for you.
Old Nov 21, 2006 | 08:57 AM
  #138
Jamaica2G's Avatar
So yah, I have an '05 with non brembo, I had the triple light problem: reversed the sensors = same problem --> bent the ABS spacers straight"er" = lights went off for a while, then it was every once in a while or whatever...
so I removed the spacers
shipped to SPC
As far as clunking, yup!...
Also went to ATL this weekend and had to soften up the front suspension.... lol BAD IDEA with hard braking! I'll be stiffening them up again today. Wohoo!
Adrian
Old Nov 21, 2006 | 02:35 PM
  #139
Aznteazer's Avatar
good to kno the bracket is the problem. hopefully it'll resolve mine.
did you vote on the SPC POLL?
Old Nov 21, 2006 | 03:42 PM
  #140
mark4x4's Avatar
I just off the phone with Charley the lead engineer at SPC about the clunking problem and this is the first he has heard about this issue. I talked to Doug, (one of the techs) last week and he was going to forward this issue on to engineering. I was just following up to see what progress was made but obviously none. Charley said that he would look into this matter, so we'll see if there will be a fix for this problem.
I talked to Peter and he knows about the clunking issue. I'll wait to see if they can come up with a fix otherwise I'll get a refund. The refund will be for only the kit only although I'll be out $200 for the install and another $150 for the alignment. Even if they come up with a fix I'll have to spend another $350.
Old Nov 21, 2006 | 04:26 PM
  #141
Gilley's Avatar
SF shops get a killing for an alignment. I paid $69 after the kit was installed.
Old Nov 21, 2006 | 04:44 PM
  #142
Aznteazer's Avatar
i paid 100 for my alignment front and rear. freakin sears don't touch non-oem parts.
agree with wat mark4x4 said. labor costs add up....
Old Dec 26, 2006 | 01:58 AM
  #143
N/A Project's Avatar
-2006 IP GT350-
Wait...how come this write-up doesn't say anything about installing brake/ABS brackets?
I'm installing it right now...please help...lol
JJ
Old Feb 22, 2007 | 09:18 PM
  #144
cungkpham's Avatar
ok, im on the bandwagon.... my front left clunks
Old Apr 23, 2007 | 07:50 PM
  #145
brettstter10's Avatar
The ball joints on my OEM arms will move easy and smooth by pushing with one finger. The SPCs seem like there is just a straight bolt in there... I can't move it at all. Did anyone else notice this? Is the assy. bolted up to tight? Will the joint losen up with a little break in time?
Old Sep 18, 2007 | 12:32 PM
  #146
izmir41500's Avatar
G35driver Addict
i'm bumping this old thread to see if you guys are still having problems with the spacers.
I think my kit only came with one bracket. I have the revised arms so i'm assuming the revised bracket is also included. i took it over to West Covina Nissan for an install, but the tech recommended against it because of the issuue with the ABS lights and such. I'm still way out of alignment in the front and barely in, in the rear after installing the spc front and rear camber kits dropped on tein basics. how much is a typical install for the spacers?
Old Jan 2, 2008 | 09:44 PM
  #147
Gilley's Avatar
I updated the post to include the Nissan PN for the lower ball joint seat, which is the cone shaped bushing. The PN is 40173-AL500.
Old Jan 2, 2008 | 10:06 PM
  #148
Boston's Avatar
Iz, I'm surprised your camber is still off so much. I'm also on Tein Basics with the revised SPC's and my alignment was perfect up front. To install the SPC spacers you need to pull your hubs. You should have two spacers per side, one hub spacer and one caliper spacer. Remember to bring the longer bolts for the top of the hub spacer. If a shop is familiar with this install it should take about an hour.
Old Jan 17, 2008 | 11:29 AM
  #149
QuadCam's Avatar
Thanks Sean for posting up this great DIY.
I went to my Nissan dealer (without the part number) and we had no trouble IDing the part from the front suspension diagram in the PARTS Computer.
A pair of the lower ball joint seats set me back $19.75 with tax. It was that or pair about $11 for a Ball Joint Separator. This way, I can still put the old A-Arms back on the car......when that time comes.
Once these ball joint seats come in, I get started on the install (probably next weekend.)
Old Jan 17, 2008 | 07:59 PM
  #150
Gilley's Avatar
Good job, Andrew.
