Camber kit worth it???
Old Dec 26, 2006 | 08:17 PM
jq1003's Avatar
Hey guys, new to this forum. Just got my G about a week ago. Ordered new tires (toyo t1r's) and wheels and I am thinking about getting a front camber kit so they last a little longer. I am not sure if it is worth it for me though. I am not planning on lowering my car. The spl kit i am thinking about getting is around $550. What do you guys think... Should i get the kit or should i just have the tires mounted the other direction after the inner gets worn down?
Old Dec 26, 2006 | 08:33 PM
MEECHIN's Avatar
If you have no plans on lowering your car, it should be fine.
If you go with springs, CUSCO front A-arms should work just fine.
If you go with Coilovers, you're best off with the 350evo A-Arms.
Just my opinion, tho.
-DRU
Old Dec 26, 2006 | 10:13 PM
Calvin's Avatar
Overglorified Altima
if youre not lowering the car then i wouldnt bother
Old Dec 27, 2006 | 06:19 AM
aleok's Avatar
the car does come stock with a little negative camber, but thats for a reason, if your not lowering then theres really know reason to get a camber kit, unless you want to adjust caster, or you want more camber.
Old Dec 27, 2006 | 09:57 AM
bambam26's Avatar
My advice is get the wheels and tires and put them on then go in for a alignment and get it checked. I had to buy arms for the back but none for the front.
zoop425
Mar 29, 2016 05:51 PM
G4ORCE
Aug 22, 2015 01:16 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
