Brembo Brake Question, I Need Help Swap Over Question Please Give Me Your Input?
Old Jan 19, 2007 | 03:46 PM
Jeff92se's Avatar
Red Card Crew
WHAT PRICE DID HE COME UP WITH? HE'S THE ONE SELLING RIGHT?
Originally Posted by mwarsh1
I Have An 05 G35 Coupe, As Many Of You Know My Year Does Not Come With Brembos, So Ive Been Looking For Somone Selling There Used Oem Kit. I Found A Guy Who Owns A G35 And Is A Mechanic, So He Was Selling His Brembos, Plus The Brembo Rotors-cross Drilled. And He Said He Would Do The Install For Me, What Do You Think Is A Fair Price For All This?
Old Jan 19, 2007 | 05:30 PM
dklau33's Avatar
Originally Posted by Gdup35sedan
I'm pretty sure they're almost the same size rotor. The 05+ might be .5" bigger in diameter. But you can beat the look of the Brembo brakes. I think that's the reason most people do the swap.
-GP-
The 05+ front brakes are a substantial 0.9 inches bigger and the rears are 0.6inches bigger. Not only that, the 05+ brakes got thicker as well.
'05+ brakes
Front: 12.6-inch x 1.1-inch power-assisted vented disc
Rear: 12.1-inch x 0.63-inch power-assisted vented disc
'03-04' non-brembo brakes
Front: 11.7-inch X 0.9-inch power-assisted vented disc
Rear: 11.5-inch X 0.6-inch power-assisted vented disc
But I think you're right, most people just get the Brembos for the looks and have no intention of using it for it's true potential.
Old Jan 19, 2007 | 05:33 PM
Jeff92se's Avatar
Red Card Crew
^^ correct. In addition, the 05 sedans also get the twin piston front calipers vs the single piston versions on 03/04
Old Jan 19, 2007 | 07:46 PM
RBull's Avatar
Rated M
'05+ brakes
I think he's looking for the Brembo brake sizes which you left out. Here is the full meal deal:
05+ Sedan and Coupe, '06 Sedan X
Front: 12.6-inch X 1.1-inch power-assisted vented disc - 2 pistons
Rear: 12.1-inch X .63-inch power-assisted vented disc - 1 piston
'03 and '04 Sedan, '04 and '05 Sedan X
Front: 11.7-inch X 0.9-inch power-assisted vented disc - 1 piston
Rear: 11.5-inch X 0.6-inch power-assisted vented disc - 1 piston
'03 and '04 Non-Brembo Coupes
Front: 11.65-inch x 0.94-inch power-assisted vented disc - 1 piston
Rear: 11.5-inch x 0.63-inch power-assisted vented disc - 1 piston
'03 and '04 Coupe Brembos
Brembo® brakes
Front: 12.76-inch x 1.18-inch power-assisted - 4 pistons
Rear: 12.68-inch x 0.87-inch power-assisted - 2 pistons
Old Feb 14, 2007 | 10:43 AM
hien.nguyen80's Avatar
1500 + 200 labor, about 1700 =)
Old Feb 18, 2007 | 12:00 PM
f r e z N Y's Avatar
Thumbs up Exactly!
Brembo® brakes
While the larger Brembo rotor diameter (although minimal) is a plus , the size, piston number and strength of the calipers with the brembo system is the bigger difference.
I'm looking to do the same swap. The feel and play in the stock calipers SUCKS! I need something that won't allow the rotors to warp as easily and will have more stable pad pressure on the rotor.
Old Feb 25, 2007 | 03:01 PM
04NismoV35's Avatar
+1, also don't forget thicker rotors as well as lighter calipers.
Too many pluses to ignore. I almost went the Racing Brake OE caliper route, but I finally found a Brembo setup.
I'm about to do the same w/ new SS lines while am at it. Do you need any additional parts if you have the rotors and calipers, ie brackets, clips, etc?
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Popes
Jul 29, 2015 05:07 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
