Floor Jack
Old Jan 28, 2007 | 09:58 AM
kenchan's Avatar
Originally Posted by aleok
but, do you guys think that a high pound rating would be better, and not have the hydraulic seals break?
if you want higher capacity, go for it. i doubt its necessary. if you
plan on lifting your car and your buddies cars often, get a real lift in
the garage.
Old Jan 28, 2007 | 10:06 AM
kenchan's Avatar
yep +1 on using ramps for oil changes, and also swaybar setting changes.
for me it's a lot faster to use ramps.
Old Jan 29, 2007 | 04:42 AM
636Racer's Avatar
Originally Posted by kenchan
screw (your words) takata, if you're going cheap get some piece of wood
from your wood working neighbor... free. i dont know which standard jack
you're talking about, but the cheepo hydraulics jacks ($20 ones) are junk
imho. it's them from my experience that the seals broke, plus takes like 20
pumps to get the car off the ground... and, why even bother driving the car
up something when you can just get a low profile jack under there?
I'll take note of that if I were to go the cheap route *big Chuck Norris thumbs up* And btw, those mini ramps (Takata or homemade) are fricken awsome....ESPECIALLY, for those who has a lip on their car or something. Or espeically if they have side skirts an and low profile body just cant seem to clear the skirt. Been there, done that.
Here's a one up. Make yourself some cheap ramps (credit to kenchan) and get yourself a good standard jack with higher weight cap, say like - 2.5 tons. That may not be necessary (credit to kenchan again) but it's just peice of mind. Those standard heavy weight steel jacks are almost always cheaper than those alum ones (unless you're buying Blue Point). Cheap seems to be kenchan's theme in this subject - not saying that it's a bad thing.
The only time I see those alum jacks come in handy is if you frequent the tracks and change out your tires and would like something lighter than a cast iron jack to haul around with your tires. Then I'd see getting an alum jack more feasible. But hey...what do I know? Bringing my old cast iron jack to the track never slowed me down.
But like I tell everyone...it's your (directed towards jepz) money. You should do what you want just as long as you're happy with your decision. cheap or not. dont matter.
the garage.
Go for it Keola. Get one of those "real" lifts in your garage. Good thing you dont live where there's Association rules. Garanz-bobaranz we'll be cruising at your house. must be "cheap" ah? The brudda not too akamai.
Old Jan 29, 2007 | 05:12 AM
636Racer's Avatar
Originally Posted by jpez179
I got the that same one from harbor frieight....but it was rated for 3000 lbs how much can urs handle??
HOLY CRAP. Just noticed the time difference between your posts. Hope it goes well for you when you get it.
Old Jan 29, 2007 | 08:49 AM
kenchan's Avatar
^^ 636Racer- having a bad day? lol hahaha.
Old Jan 29, 2007 | 01:59 PM
636Racer's Avatar
yah, I think I have a tear coming along
Old Jan 29, 2007 | 02:18 PM
Gilley's Avatar
I'd love to get a real list in my garage, but my ceiling isn't high enough.
Old Jan 29, 2007 | 02:24 PM
bobshuai's Avatar
I have jacks for you, pm me if you want more information. FYI, right now you can't buy it that price from Harbor freight anymore they raised the price to $84.99 plus that is 3000lb capcity, it is for the light weight track cars. I have seem someone use that to lift Ford, CAT 4 doors and the jack's seal just broke. You need more capactiy. 3000lb equal 1/2 only.
Old Jan 29, 2007 | 02:34 PM
bobshuai's Avatar
yes sometimes cheap isn't good unless you know what you are doing. Cheap screw driver cost $025 and break after 5 mints is okay. Cheap calculator cost me $5 and break within a week is okay.I will consider twice if I buy anythign for my car. If anyone will buy the knock off exhuast system with just few bending metal tubes or intake then you are entitle to buy anything you want. But if you always want the best products for your car then why anyone will consider the cheap stuffs regardless HP gain or maintains the car?
Old Jan 29, 2007 | 04:28 PM
kenchan's Avatar
you can probably get one of these in your garage if you lift your car often.
they have all sorts of other lifts and not too expensive for what they can
do.
for most people, a regular racing jack should do the trick. i only lift my
car twice a month during the winter and maybe no more than once every
other month in the summer months.
check this out:
http://www.gregsmithequipment.com/Ph...ode=TPPRO%2D6M
Old Jan 29, 2007 | 04:32 PM
kyu1021's Avatar
anyone know where to get floor jack pads?
Old Jan 29, 2007 | 04:47 PM
kenchan's Avatar
http://www.ultimategarage.com/shop/a...09e588645b9b88
Old Jan 29, 2007 | 05:02 PM
636Racer's Avatar
do.
check this out:
Money must grow on trees where you're from.
Old Jan 29, 2007 | 05:06 PM
kenchan's Avatar
no, i just work like everyone else.
Old Jan 29, 2007 | 05:26 PM
  #30
636Racer's Avatar
I hope so.
