07 sedan w/ coupe or 350z springs.
After some investigation and after Hikos_G pointed out that his springs had the same product number with the 03-06 sedan G. I have decided to try the coupe's springs and the 350z springs on the 07 sedan. This might work well with the 07 just like the 03-06 sedan. I am expecting the drop to be even or more to Hikos_G. I will post pics after the setup. Just though i would try to something rather than wait for the other brands to come out.
Looking forward to seeing your results Koyoki! I'm guessing that the drop will be a little more conservative than the H&R drop, based on seeing other pre-06 sedans running the sportier(and lower) Z/G coupe springs.
Should turn out JUUUST right, without being too 'slammed' or too high.
Can't wait!
Can't wait!
Can't wait!
Can't wait!
Sorry i am taking soo long. I have mid-term and lots of homework. Anyway, we have schedule monday morning to do the drop.So check back on monday night or remind me because i am soo busy. Everything will be done and pics will be taken. SO wish me luck.
ENVautoDetailing.com
too bad i dont have an 07... i would try out allll of the different springs for you guys and datalog all the results, i have nothing better to do at work now that were not busy, have plenty of time to work on my own car.
-GP-
-GP-
BTW ... try to remember measuring height before and after drop.
Ok, here are the results. The springs from the 350z and the g35 07 are SAME for the front springs. The height is the same. Sadly but true the fronts cannot be use for the swap. Anyway. The rears will lower beautifully. There for the conclusion is that the OEM springs can only be used in the rear. So tein H-tech for the 350z are the best item to drop you car with. That is my conclusion. It is a very depressing day but i think i will try to get a cheap set of 350z h-tech springs and try them. After what i have compared too i am pretty sure the 350z h-tech is the best bang now. This is the comparison from Jz39 the h-tech springs and the stock g35c springs. So i am very sure it will work this time. Hey they say 3rd time is a charm.
https://g35driver.com/forums/showthr...g35+350z+htech
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
