Just got BBK, need spacers now
Old Jan 30, 2007 | 09:29 PM
waijai's Avatar
i.love.gold
Just picked up a used set of Brembo GT brakes (not the OEM Brembos). These things clear but only have enough clearance to barely fit a sheet of paper through, so now I'm thinkin about some 5mm or 8mm spacers. U guys have any experience w/ those Ichiban spacers w/ new studs?
Old Jan 30, 2007 | 10:45 PM
extreme4377's Avatar
Lexus IS350
If the wheels clear the brakes, why do you need spacers? Just personal preference?
Old Jan 30, 2007 | 10:48 PM
Calvin's Avatar
Overglorified Altima
sounds like he wants to be safe rather than sorry...which i understand
Old Jan 31, 2007 | 08:53 AM
SFLG35's Avatar
FGC President
never usedthem but i can get them.
yeh i think i would rather be safe then sorry. what about maybe just a 2 or 3 mm spacer??
Old Jan 31, 2007 | 11:29 AM
Andy@Performance's Avatar
You should run spacers. The BREMBO caliper will expand and flex when it heats up and will cause clearance problems. Next time you may consider a BBK with less caliper flex.
Old Jan 31, 2007 | 08:20 PM
waijai's Avatar
i.love.gold
cool thanks Andy. I got an awesome deal on them, so I couldn't pass up the chance. $1300 for a slightly used set.
Old Jan 31, 2007 | 08:57 PM
636Racer's Avatar
Interesting...what manufacturer makes calipers with the lesser problems.
Old Jan 31, 2007 | 11:15 PM
Sundeviljay's Avatar
i can barely fit a business card through mine in the rear...i have stoptech's and this is after i put a spacer in. had them for almost a year with no prob's at all
Old Feb 1, 2007 | 12:10 AM
redlude97's Avatar
you can pick up 3mm spacers on ebay, i wouldn't run anything over that without getting longer studs
Old Feb 1, 2007 | 12:23 AM
yeah i forgot...longer studs are key...get the nismo studs to be safe
Old Feb 1, 2007 | 11:20 AM
Thats an awesome deal! Just make sure you run some 5mm spacers.
What rear caliper are you running?
Old Feb 1, 2007 | 11:27 AM
STOPTECH calipers are pretty good, some of their calipers are completely forged like the ST22 and the rest are squeeze forged. The front calipers use a bolt on bridge to minimize caliper flex without sacrificing cooling from the caliper. With less caliper flex you will have a stronger pedal feel during extreme braking conditions as well as less vibration and pad taper.
Project Mu and Endless also make very strong calipers. Both offer fully forged calipers so you should experience less caliper flex.
Old Feb 1, 2007 | 01:42 PM
i have stop tech 4 piston all around
Old Feb 1, 2007 | 01:44 PM
Hi-TechG35's Avatar
Post some pics. The Brembo Gran Turismo kit is sweet! I don't blame you for getting the spacers though I did the same thing when I noticed I probally didn't have much space btween my wheel and caliper.
