replacing my brake pads and fluid
Old Nov 26, 2003 | 11:19 AM
jonathang35's Avatar
I will be replacing my brake pads, fluid, and installing stoptech brake lines this weekend.
Anyone who has done this have any advice??
thanks
Old Nov 26, 2003 | 01:40 PM
3point5SE_Auto's Avatar
Re: replacing my brake pads and fluid
bleed and bleed and bleed. After I did mine it took several more bleeds to get it just right. I also had my rotors turned. Just an old habit for me but something to consider. Use a higher grade brake fluid such as DOT4 or even better, Motul 600 (equivalent to DOT 5.
If you have to remove more than two bolts on each wheel to pull the pads off, you are screwing up.
Better Life thru Chemistry
Black on Black 03.5 Sedan 6MT - Custom Catback, Custom Intake Tube, HyperGround Kit
Old Nov 26, 2003 | 03:13 PM
belerin's Avatar
Not sure if you guys heard, but Infiniti just released a statement saying they'll cover all brake maintenance and repairs for three years including rotors, pads, etc... I am not sure if you have aftermarket brake components or are going that way, but if not you may want to contact your dealer and take advantage. I got my letter in the mail last week.
Patrick Bovee
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
emorehs
Jul 17, 2015 09:45 AM
