Stoptech VS Racingbrake VS OEM
Old Feb 5, 2007 | 10:23 PM
cloud's Avatar
Which would be a good rotor replacement for a 2005 G Coupe(non brembo)?
I just got my endless SSY & VN pads from Japan after a 6 week wait.
There are very limited options.
The stoptechs or racing brake or keep the OEM?
Which is superior?
Old Feb 5, 2007 | 10:26 PM
aszatk01's Avatar
if you're keeping everything else the same i'm not really sure that one would really be better than another....
i ended up getting the racing brake cross drilled/slotted rotors because they looked nice. but i dont notice any better braking.
from what i've heard the cross drilled/slotted is actually a bit worse, but i got them more for looks...
Old Feb 5, 2007 | 11:35 PM
ttrank's Avatar
Grocery getter
What about the racingbrake 13" oem caliper upgrade? Better, larger rotors and you can still use those pads.
Old Feb 6, 2007 | 12:28 AM
cloud's Avatar
I would have gotten it if the caliper relocation bracket wasn't red lol
Old Feb 6, 2007 | 03:51 AM
636Racer's Avatar
What's your purpose for upgrading your brakes?
If you just want a "one-up", find a used set of Brembo brakes. Going bigger isnt necessarily better if you're never going to see the track. A good upgrade to your stock setup would be to get more aggressive pad compounds, braided s/s or kevlar brake lines, and slotted rotors. Unless you're planning on frequent trackdsays or sneak in some scca roadracing (not auto-x) then I'd recomend going with something bigger to get some dependability and reliability in your brakes during hard driving.
Old Feb 6, 2007 | 04:30 AM
cloud's Avatar
yeah which is why i'm trying to pick the better rotor...
Old Feb 7, 2007 | 12:05 PM
GGRJR's Avatar
Like TTrank said going the RB OE BBK, will use your stock calipers, with option of upgrading to 4 pot calipers later. Just going to the larger rotors, will improve brake fade to a degree, mainly due to the larger heat sink involved and better internal vane design. I have the RB OE BBK front and rear, and have noticed zero fade under hard driving. As for the brakets you can buy a brake paint kit and paint these and your calipers at the same time, something like G2.
Old Feb 7, 2007 | 04:05 PM
cloud's Avatar
http://mynismo.com/products/?id=3292
INF3000 INFINITI G35 2005-2006 ; exc G35X
is that better than the stage II direct replacement rotor? it costs more i think.
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
johnadlertech
Interior
Sep 4, 2015 12:26 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
