im lowering over an inch, do i need a toe kit?
Old Feb 16, 2007 | 01:39 PM
  #76
b00stedjustin's Avatar
A toe kit is a kit that adjusts your toe newb ie SPC toe bolt kit
don't you get this with a camber kit if it requires it. Also, cant the adjustments to the toe just be done manually while it is aligned. I'm sorry I've never heard of a toe kit, and I've used various camber kits on my cars and have had everything setup perfectly.
Old Feb 16, 2007 | 01:49 PM
  #77
redlude97's Avatar
It doesn't come with all camber kits, SPC's kit includes the toe bolts,or they can be purchased seperately and used with other kits. All other camber kits use camber arms and "toe" or radius arms to adjust toe, which is the incorrect method, and most sell them seperately, so the best thing to do is to buy the SPC kit, or buy the camber arms from another company individually and purchase the SPC toe kit
Old Feb 16, 2007 | 02:05 PM
  #78
ISMSOLUTIONS's Avatar
+1^^^^
Right on the money...
Old Feb 16, 2007 | 07:35 PM
  #79
PEARL-G's Avatar
ok, heres a pic of the drop with the system, mind the snow. so what do you think? i want the front to match the back, suggestions?
Old Feb 16, 2007 | 07:42 PM
  #80
GThIrtYFiZle's Avatar
ISMSOLUTIONS, i am in NYC. You know whats the best part about the alignment place I went to? I didnt pay them because they said when i get the camber kit come back and we will square off then. F*ck that, they are not seeing me no more. Any suggestions. What should my front camber and toe be at?
Old Feb 16, 2007 | 07:52 PM
  #81
redlude97's Avatar
Get s-techs for the front and leave the back stock? Only other option I see is to get coilovers and raise the back end up until its even, or get rid of your stereo
Old Feb 16, 2007 | 08:13 PM
  #82
G&Z's Avatar
G&Z
alright guys, if i get the stillen toe and cambers i can adjust from stock height to over an inch lower. or does the toe kit only work if you are really low? what i am trying to say is if i lower it over an inch and get this setup and end up not liking it and lower it only like a half of an inch is this still feasible
Old Feb 16, 2007 | 08:18 PM
  #83
cturnbull802's Avatar
an alignment rack would tell you exactly what you need
Old Feb 16, 2007 | 09:35 PM
  #84
redlude97's Avatar
THe stillen parts will work even at stock height, but I don't recommend the stillen "toe" arms at all, get the SPC toe bolt kit instead if you insist on using the stillen camber arms, or my recommendation is to just use the SPC camber and toe kit, its the cheapest one available and works the best
Old Feb 16, 2007 | 11:39 PM
  #85
Easiest way is S-techs...best way, coilovers...Rick
Old Feb 17, 2007 | 02:07 PM
  #86
G&Z's Avatar
G&Z
hey thanks redlude, but why are the spc bolts better. the stillen look better cuz they have bushings n junk. also anyone looking to start a business in auto parts. these look like the way to go. looks like the cost to make these camber, toe kits is like 5 bucks @ the most. and they sell for 700 800. crazy
Old Feb 17, 2007 | 03:36 PM
  #87
BadBoy06's Avatar
Its all the test and development that raises the $$$$$$
Old Feb 19, 2007 | 04:12 PM
  #88
Zerk's Avatar
FYI, AJUSA.com sells the eibach ie SPC rear kit for $143.01 shipped, best price I've seen and its where I ordered mine from
That is a great price. Are you positive this is the same kit?
Old Feb 19, 2007 | 04:18 PM
  #89
BadBoy06's Avatar
sounds like a small part of the kit?
Old Feb 19, 2007 | 05:26 PM
  #90
I just received mine. Ended up paying $234 shipped from partshippers.com. I know others sell it for a bit cheaper shipped but I figured I would give them another try after i had problems with the springs coming in, and this time they were very fast and easy to contact. They look like they can be adjusted a lot.
