im lowering over an inch, do i need a toe kit?
Old Feb 19, 2007 | 08:18 PM
  #91
redlude97's Avatar
Originally Posted by Zerk
That is a great price. Are you positive this is the same kit?
Yes, I ordered from there, and the parts even say SPC on it. Call eibach and give them the part number if you are still not satisfied but they will tell you the same thing
Old Feb 19, 2007 | 08:19 PM
  #92
redlude97's Avatar
Originally Posted by GThIrtYFiZle
I just received mine. Ended up paying $234 shipped from partshippers.com. I know others sell it for a bit cheaper shipped but I figured I would give them another try after i had problems with the springs coming in, and this time they were very fast and easy to contact. They look like they can be adjusted a lot.
A little bit? $100 is more than a little bit to me...
Old Feb 19, 2007 | 08:29 PM
  #93
GThIrtYFiZle's Avatar
The reason I said a lil bit was based on all of the places I searched, and the cheapest was IApdirect, or something like that for 200 shipped.
Old Feb 19, 2007 | 08:32 PM
  #94
Hey redlude I have a question for you. I am doing the springmount mod tomorrow, how much should i cut to get an even drop. Should I measure from floor to top of fender both front and rear and base my decision on that. I dont want the rear to be lower, thats why, i want it to be perfect. About how much lower does the front usually go.
Old Feb 19, 2007 | 09:54 PM
  #95
redlude97's Avatar
For an even drop, ~3/8-1/2", if you already installed the springs, just measure how much lower your want the rear to be, and cut that amount, and it should be pretty close to spot on, the rubber doesn't compress much
Old Feb 21, 2007 | 11:24 AM
  #96
THMotorsports's Avatar
We have and had it for $199 Shipped btw.
Old Apr 29, 2007 | 04:29 AM
  #97
MechEE's Avatar
Originally Posted by Rphillips6487
I agree wiuth everything you said ismsolutions, except the spc front camber
lots of people claim to have problems with the front cambers braking which is why spc has reconstructed their front a-arms
i went basic coilovers, 350evo a-arms, and spc rear w. toe bolts
also getting the stillen sway bars for even better handling
I figure with RAS on my car already, the sways will be amazing
Have you had any issues with the SPC rear and your Rear Active Steering? Rumor has it that they're not compatible.
Old Apr 29, 2007 | 12:57 PM
  #98
bsimas's Avatar
Thanks for the good information.
Originally Posted by ISMSOLUTIONS
OK -
If you drop the car AT ALL - your toe and camber will go out of line. Toe is adjustable front and rear, but if you drop 1" or more, you'll need the toe bolts for the rear. There is more adjustment in the front stock, so you'll likely be OK with toe there.
NOW - camber - you'll NEED to adjust camber for handling, control, and tire wear. You WILL NEED rear camber kits and front kits if you go over 1/2". The lower the car, the more negative the camber is, and there is ZERO factory adjustment for camber on the car. The best setup I have seen, regardless of money spent, are the SPC kits - for both front and rear. Get the toe bolts for the rear as well.
The kits will give you ALL you need for rear toe and camber adjustment, and camber, caster and toe for the front. The SPC kits are also the cheaper ones overall for an entire car solution.
What happens if you don't do the camber adjustment? Well, tires will wear faster on the inside edges. How much faster, depends on the drop and how much MORE negative camber you have than stock. Our cars are negative cambered to begin with and will wear unevenly to begin with. I got 10,000 out of my tires before putting the front kits on them...but I could have gone longer....BUT NOT A GREAT IDEA!!!
Why? Well handling will suffer immensely. When you go over bumps, the entire car will shift to the right or left, depending on which side has more camber...this is really unsafe and scary when it happens and your not ready for it. Also, general handling and traction will suffer - because the contact patch is reduced by 20%-30% - sometimes more.
If you lower your car - with springs, coil-overs, etc...no matter what, you will need to adjust camber. some of the advanced coil-overs have camber adjustment in the upper ***** - but they are more than 2X the money of the non-adjustable coil-overs AND more than 4X the cost of the SPC front camber kits to begin with.
Bottom line - if you lower - adjust the camber and toe properly with a proper kit. SPC's kit rocks and has a huge amount of adjustment.
Check out THMOTORSPORTS - PM Eddie and go for it!
Rick
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
linedr89
Aug 17, 2015 05:11 PM
itschuckster
Jul 25, 2015 08:07 AM
jimNC
Jul 25, 2015 05:47 AM
