Aftermarket sways = endlinks going bad?
Old Feb 27, 2007 | 11:19 PM
  #31
BadBoy06's Avatar
Originally Posted by FenixL1P
I've had mines on for a year now and they are set to medium/medium (middle holes all around)....
how many miles have you put on them?
medium..may be the way to go
Old Feb 28, 2007 | 10:09 PM
  #32
JZ39's Avatar
From experience:
1) There is a revised part number for the 05 rear links. I assume it is a revised part.
2) My Stillen sways did make my rear links go bad. Basically, I got a thunk from one side when I would go over uneven pavement. Once I put the new OEM links on I have had no problems.
I was running med/med when the link failed and since then I have been running med front and stiff rear.
Could never go back to OEM body roll, no matter how many end links I need to replace.
Now, get a front strut bar and see how good the handling can really be!!!
Old Mar 1, 2007 | 08:51 PM
  #33
fbw5595's Avatar
Originally Posted by JZ39
From experience:
Thanks for the post.
How much did the OEM end-links cost?
How many miles were on your car when this issue accrued?
I just bought some sways and I am debating if I should replace the end-links when I put them on; my car has 60k miles on her.
Old May 31, 2007 | 04:01 PM
  #34
bambam26's Avatar
I called the Infiniti in Orlando about the end links the OEM are 35 a piece for the front and 35 a piece for the rear. The front ones are the same for the 03-06 the rear are different form the 03-04 and the 05-06.
Old Jun 6, 2007 | 05:59 PM
  #35
strlen's Avatar
chairman roflmao
Has anyone tried the Nismo end-links? Will they work with the Stillen sways? They seem pricey, but worth a shot. They're adjustable also:
http://mynismo.com/products/?id=5229
Old Jun 9, 2007 | 04:17 PM
  #36
bambam26's Avatar
If the new stock end links I bought go bad I will defiantly look to that route.
Old Jun 13, 2007 | 11:36 AM
  #37
G35fromPA's Avatar
I was looking at the Everythingg35 site, and I noticed that the front end links for the 05-07 sport suspension equipped coupes are different from the non-sport coupes. I would think you would want those instead of the non-sport ones.
Old Jun 16, 2007 | 11:29 AM
  #38
bambam26's Avatar
Well after getting under the car I found that the 05 end links won't fit on my 04. The weird thing is I call infiniti and they said that the brackets are the same for all years. The bolts on the 05's are thicker than on the 04 so they will not go through the brackets I am totally confused on this.
Old Jun 16, 2007 | 12:48 PM
  #39
G35fromPA's Avatar
Are the brackets different part numbers?
Old Jun 16, 2007 | 02:38 PM
  #40
bambam26's Avatar
Nope the brackets are the same parts numbers. i am really stumped I am going to look again and take pics along as I can find my digital camera. I talked to the parts person at the dealer and the brackets are the same for 03 up.
Old Jun 16, 2007 | 05:47 PM
  #41
G35fromPA's Avatar
Hmmm...that doesn't make any sense then. Maybe they gave you the wrong endlinks?
Old Jun 16, 2007 | 06:24 PM
  #42
bambam26's Avatar
Dam, they did I just checked they gave me the front rods for a 05 350z.. ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh
Old Jun 18, 2007 | 07:55 PM
  #43
bambam26's Avatar
Well this is were things get weird. I took them back today. the guy showed be the computer the 04 an d 05 have the same rear endlinks. So the skinny ones are going on the back. The thick ones he gave me are for a 04 he said he showed me the computer again the 04 one's are thick as hell. I have to put them on still but I know the ones that are on there now are skinny as **** so I really don't know what to think..
Old Jun 19, 2007 | 07:19 AM
  #44
G35fromPA's Avatar
When I look at the Infiniti Parts USA site, the rear links seem to have different prices and different year indications, so I can't understand what the parts guy is telling you:
http://www.trademotion.com/partlocat...05&catalogid=2
rezendvous420
May 31, 2020 01:26 PM
bTanz
Oct 15, 2015 02:31 PM
Danielek
Sep 20, 2015 12:08 PM
derres
Aug 28, 2015 03:27 PM
neight
Steering & Suspension
Aug 7, 2015 02:48 AM
