Best Brake Pads
Old Feb 26, 2007 | 09:50 PM
nalinc23's Avatar
Best Brake Pads
Hey I am on a tight budget after a $600 repair (mostly nit-picking) bill and some other debt i am taking care of but I was told by the stealership I need front brake pads (they wanted $160 so i said no). What do you reccomend for the best pads with the least dust and the quietest with oem or better performance. Not interested in racing pads or anything too expensive. Thanks guys!!
nate
Old Feb 26, 2007 | 09:58 PM
burns420's Avatar
i put on EBC greenstuff pads. they are very quiet and are pretty cheap. there is still a little bit of dust, but it will only be noticeable after a month or so. much less dust than stock. whatever you get, just have them put on properly or they will squeek
Old Feb 27, 2007 | 01:37 AM
accordhybrd's Avatar
www.hawkperformance.com
They will have something for you
Old Feb 27, 2007 | 02:46 AM
hien.nguyen80's Avatar
I dunno how all the HAWKS are, or if they're different for SEDANS, but stay away from the HPS... mine squeal and squeak like there's no tomorrow.
Old Feb 27, 2007 | 10:35 AM
I love the Hawk HPS, I have them on my 4runner and they work well and do not squeal at all.
Old Feb 27, 2007 | 10:54 AM
SilverII's Avatar
Originally Posted by S.E.
my project mu b-force squeal like death after only a few weeks but i thik they may be on wrong......
mine had a slight squeal in the beginning, but it went away after a few heat cycles.
Old Feb 27, 2007 | 11:09 AM
gary c's Avatar
Hawks are great if you follow the "HowTo's"
Chances are you didn't follow the break-in proceedures or they were installed
wrong. If you do a search prior to install the answers are on this site, that's
why we're here!
Old Feb 27, 2007 | 11:33 AM
Q45tech's Avatar
the quietest with oem or better performance ??
At what temperature and application speed? Unlikely you will find anything that works cold [under 100F]...........friction function of pad temperature and application speed [difference between rotor and stationary pad].
Old Feb 27, 2007 | 11:43 AM
bwassul's Avatar
there's a good review of pads in the current issue of "DSport".
Old Feb 27, 2007 | 11:21 PM
BadBoy06's Avatar
why we're here!
got them on my wifes car with no issues..did follow the brake in though
Old Mar 3, 2007 | 04:46 PM
nalinc23's Avatar
So do we think Hawk are better than Green Stuff?? I also will need 2 front rotors, stick with OEM here? I need to keep this as cheap as possible without sacrificing quality.
Also what could you do during a brake pad install wrong that would make them squeal worse?
Old Mar 3, 2007 | 04:51 PM
Nismo G's Avatar
Just replace them with another set of OEM pads...
-sean
Old Mar 3, 2007 | 09:50 PM
avs007's Avatar
I just installed Project Mu Type-NS. So far they are great, dead quiet, and so far no dust. With the OEM pads, I would've had to clean my wheels by now So far they seem to grip just as well as OEM, except much smoother.
I also put on Akebono ProACT Ceramics on my wife's Acura TL, as well as my daily driver Pontiac Grand Prix GTP. In the pontiac, they have much better cold-bite than the Hawk HPS that were on there before. (I used to blow past the stop sign in my cul-de-sac accidently everytime I switched from the G to the GTP, until I put the Akebonos on there.
The akebonos are quiet, and produce minimal dust as well... (I got them from tirerack) I got the Project Mu from mynismo.
Old Mar 3, 2007 | 09:56 PM
avs007's Avatar
If you don't pay attention to what you are doing, the retainer clip can get bent, and scrape the rotor.
Old Mar 3, 2007 | 11:00 PM
nalinc23's Avatar
Also I am going to need 2 front rotors, whatever is the cheapest...I assume OEM? Where could I find these online as well?
