350Z Springs and shocks vs. Eibach pro kit
Old Feb 28, 2007 | 01:19 PM
ttrank's Avatar
Grocery getter
Originally Posted by Sir Boostalot
So even with the eibach prokit I would need a camber kit
Does anyone know if the prokit gives an equal gap front and back?
Yes and almost yes.
The eibach will put you a tad out of spec.
The rear has a little bit less gap than the front.
Old Feb 28, 2007 | 01:30 PM
Sir Boostalot's Avatar
Originally Posted by ttrank
Yes and almost yes.
Would you say that the 350Z springs sit nicer then the prokit.
Old Feb 28, 2007 | 03:15 PM
ttrank's Avatar
Grocery getter
No, the 350Z springs are too high for me. I like my fenders to sit right at the tire or even a little tucked in the front. That was how my H&R's sat. rear was flush and the fronts were tucked 1/4-1/2"
Old Feb 28, 2007 | 03:17 PM
gramdacious's Avatar
Of course it matters a ton what size tires you are gonna run. I'm a little lower in the rear but overall sits nicely IMO. I have 45 series tires so the gap isn't too pronounced.
Old Feb 28, 2007 | 03:51 PM
Pska's Avatar
any word on if you'd need a camber kit for sure or not? I'm hoping to pick up a set of unrevised springs sometime this spring.
if you DO, anyone know about how much they run?
Old Feb 28, 2007 | 05:08 PM
jimmyc13's Avatar
My buddy has some laying around his garage, my only concern is the wheel gap. Do you know if its going to sit lower in the back and would I need a camber kit
They'll drop you 1" in the front and 1" in the rear. In the rear, for sure you'll need a camber kit...in the front, I've heard mixed stories.
I went w/ the Z springs in the front and Coupe springs in the rear (1/2" drop), as it even's out the fender gap from front to rear (the G sits 1/2" higher up front @ stock). This seems to be a pretty common setup lately, so that's why I went with it...plus it's inexpensive.
Old Feb 28, 2007 | 05:23 PM
I had mine put to coupe specs and my fronts are fine. The rear is barely off, haven't observed any crazy tire wear issues. the rear camber kits can be found for around $100 from what I've seen.
Old Feb 28, 2007 | 06:41 PM
redlude97's Avatar
If you want something stiffer than stock, Eibachs aren't it, they are progressive so they will feel soft most of the time, and will allow the body to roll significantly before the higher springrate coils kick in during a turn. OEM 350z springs are your best bet
reavensf
Sep 17, 2015 11:30 PM
Dundermuffin666
Aug 14, 2015 04:01 PM
si_driver
Aug 11, 2015 07:08 AM
wuppiedog
Aug 7, 2015 11:16 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
