On The Brembo's How Many Squeel Plates Should I Have?
Old Mar 1, 2007 | 03:00 PM
mwarsh1's Avatar
How Mnay On Rear's
And How Many On The Fronts?
Old Mar 5, 2007 | 10:41 PM
mwarsh1's Avatar
on the oem brembo pads the shims are already on there>
Old Mar 5, 2007 | 10:53 PM
mwarsh1's Avatar
but the brembo have the shims on there already? what do the squeel plates looks like?
Old Mar 5, 2007 | 10:54 PM
mwarsh1's Avatar
mr filanj do you have any pics ?
are you sure there is one one each side of each pad?
Old Mar 5, 2007 | 11:06 PM
mwarsh1's Avatar
this is what i have and i only have two of them not 4,
i think now brembo makes teh shim attached right to the pad, so that metal piece is not neccesary.
Old Mar 6, 2007 | 11:20 PM
mwarsh1's Avatar
i tried calling no soby knows anything.
Old Mar 7, 2007 | 12:07 PM
sillief00l's Avatar
Smile
The service manual I read said that the 03-04 OEM Brembo pads had shims and wear sensors built in. The shims are non-removable, and the wear sensor is just the metal tab.
I also had a previous experience with the aftermarket RacingBrake shims.
https://g35driver.com/forums/brakes-suspension/136430-help-new-brembo-brakes-feel-soft.html
To make a long story short, MAKE SURE YOU GET THE REVISED VERSIONS OR ELSE YOU WILL HAVE A SOFT PEDAL. They are otherwise excellent in eliminating brake squeal, but I have a sense that the brakes were stronger without any shims at all.
Old Mar 7, 2007 | 12:29 PM
Brando's Avatar
Originally Posted by filanj
They are DEFINITELY removeable. The picture he posted above is of the "non-removable" shim off of the OEM pad. I wouldn't have been able to put all of the shims on the new set of pads if they were "non-removable."
Ditto....I re-used mine when I put on my Project mu pads.
06g35
Feb 14, 2022 05:59 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
nissandrifter32
Dec 22, 2015 04:28 PM
tadmcmichael
Brakes
Oct 18, 2015 01:47 PM
boostelevator
Brakes
Oct 5, 2015 08:56 AM
