question on 2007 brakes?
Old Mar 4, 2007 | 06:52 AM
gcoupster's Avatar
Ok so i have a 2004 g coupe with-OUT the brembo brakes. After doing some research i found out that my brakes are 11.6 inch front and 11.5 rear in rotor size. I also found that the 2006-2007 g coupe came with 12.6 and 12.1 front and rear rotor sizes. My question is when it comes time to get new brakes can i simply order the 2007 rotors and pads and just swap them on or is it not compatable??? Furthermore will i have a noticeable diference in stopping power ???? Tried searching and found nothing so id appreciate anyone's insight thanks in advance
Old Mar 4, 2007 | 08:11 AM
G35 Mass's Avatar
the brake caliper wont fit on. I know some BBK kits have brackets to raise the height of the stock caliper (inexpensive alternative to new calipers), but that comes with their larger rotors.
Old Mar 4, 2007 | 02:25 PM
mykmar10's Avatar
I have a 2k4 coupe and I swapped out my 2k4 brakes for the 2k6 brakes (calipers). Everything is a direct bolt on. I have cross drilled and slotted rotors and SS brakelines from R1 Concepts (also in the 2k6 12.6" front and 12.1" rear). There is less brake fade compared to the 2k4 brakes. The SS brake lines give you a little better brake feel. I am completly satisfide with the swap. (they also look better than the smaller 2k4 brakes)
Old Mar 4, 2007 | 05:13 PM
gcoupster's Avatar
thanks bro you totally made my day so do i need the front and rear calipers form an o6 or are the rear calipers identical from 04 to 06 and also after i get the calipers rotors pads and lines is there anything else i will need to make this work or is that it????
Old Mar 4, 2007 | 06:11 PM
mykmar10's Avatar
To keep the same level of brake ballance you need the rears also. The rear calipers are the same but are pushed out a little bit to fit the larger rotor. You won't need anything else. Every thing bolts right up to the factory spots.
Old Mar 4, 2007 | 06:19 PM
gcoupster's Avatar
awesome thanks for the input now im assuming my best bet in getting the 06 calipers would be through the dealership?????? any idea what it will run for all 4???
Old Mar 4, 2007 | 11:10 PM
mykmar10's Avatar
You can check with the dealer but you may be better off buying from someone who put a BBK on their "G". You can save a lot of money that way. Thats how I got my set.
Old Mar 5, 2007 | 12:32 PM
04NismoV35's Avatar
Here's another option that I was looking at: 13" Racing Brake OE Caliper BBK
What's nice is that you get a 13" rotor, however, I believe the front calipers on the '05+ are better than the older '03-'04 calipers.
Old Mar 5, 2007 | 04:31 PM
dklau33's Avatar
Yep, the '05+ calipers are two piston.
Old Mar 5, 2007 | 08:24 PM
avs007's Avatar
If I put the 05+ calipers on 05+ sized rotors, do I need to replace my spare tire with a bigger one, or will it still fit?
Gip
Aug 24, 2015 05:31 PM
miata007
Aug 17, 2015 04:36 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
