Need Help With My Brembo Conversion, Please Help Me I Can't Deal!
Old Mar 9, 2007 | 11:59 PM
mwarsh1's Avatar
Ok So I Get My Ss Brake Lines, And I Try And Put Them On And They Wont Line Up, So I Then See Whats The Problem,
???? Are The Brackets For The Rear Calipers (brembo-2004) The Same As The Brackets From The Stock 2005 Non Brembo Brackets????
Anyone With Info Would Be Greatly Appreciated?
Old Mar 10, 2007 | 12:04 AM
Mr_pharmD's Avatar
i used my stock 05 brackets for the ss bc it felt more snug vs the goodridge brackets.
Old Mar 10, 2007 | 12:12 AM
mwarsh1's Avatar
I Put Brembos On My Stock 2005 Oem Brake Brackets, Is Taht Ok? Do The Stock Oem Brackets Fit The Brembo Caliper?
Old Mar 10, 2007 | 01:38 AM
Mr_pharmD's Avatar
thats wat I did with my 05 and it fits better then the one provided with the ss lines. Let me know if u feel any difference in braking bc I didnt feel any difference compare to the 05 sports suspension.
Old Mar 10, 2007 | 07:38 AM
mwarsh1's Avatar
Your Not Understanding My Question Are The Brembo Brackets(that Hold The Caliper To The Car) From 2004, The Same Bracket That They Used In 2005 On The Stock Caliper?
Old Mar 10, 2007 | 07:51 AM
GR8TG35's Avatar
mwarsh1.....I can't say for sure, but I would think they are not the same.....its two different braking systems. Unless the 05 rotor size is the same as the brembo's. I don't think the stock hardware for my 2004 non brembo brakes would work either.
Hopefully someone with experience will chime in and help
Good Luck
Old Mar 10, 2007 | 07:54 AM
Brando's Avatar
Cool
I understand what you are aksing.....the caliper brackets, not the line brackets....
But maybe it would help to post it in the "Brakes & Suspension" forum...
Here's what I found with a quick search
"The front is straight forward and all hardware you remove, except the dust shield and brake lines, is reused. The rear requires different bolts to secure the caliper to the hub."
Good Luck
Old Mar 10, 2007 | 09:23 AM
mwarsh1's Avatar
ok thanx any one else?
Old Mar 10, 2007 | 09:37 AM
O NO's Avatar
Staff ALUMNI
M
Search is your friend ...
There are several threads that have been started on this subject in the past.
Good luk in your search.
silvernole12's Avatar
The brackets are the same, you just need the mounting bolts for the rear brembo calipers.
Old Mar 10, 2007 | 10:31 AM
mwarsh1's Avatar
Thanx Silver Nole
Old Mar 10, 2007 | 11:31 AM
mwarsh1's Avatar
This Should Be Called Them Moved Forum????
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
vQFamily
Sep 30, 2015 01:17 PM
9tray turbo
Sep 29, 2015 10:22 PM
