BBK few questions
Old Mar 21, 2007 | 01:02 PM
  #31
Neal376's Avatar
Originally Posted by KrazyEd
ask Ma_Sha1 he has it..here is a link to his thread awhile ago
https://g35driver.com/forums/brakes-suspension/95760-wilwood-13-6-bbk-arrived.html
he has the 13.06 4 pot one
Old Mar 21, 2007 | 01:16 PM
  #32
cato's Avatar
SouthernComfort Moderator
See my sticky thread of my 6-pot ArizonaZCar Wilwood install. At the top of this forum.
Old Mar 21, 2007 | 01:18 PM
  #33
Neal376's Avatar
yea, iz read it...
you said it dusted...is it possible to order the AZCar BBK will low dust pads?
and + I have 19inch wheels and I wanted something a wee bit larger
Old Mar 21, 2007 | 01:35 PM
  #34
cato's Avatar
You will need to ask Dave at ArizonaZCar about low dust pads. The ones I have dust like the OEM ones.
Old Mar 21, 2007 | 01:45 PM
  #35
KrazyEd's Avatar
No..he has the 13.6 kit from fast brakes. He does not have the Arizona Z 4-pot kit. If you read the thread he states it further down.
https://g35driver.com/forums/showpos...1&postcount=37
Old Mar 21, 2007 | 01:58 PM
  #36
Neal376's Avatar
thats what I keep telling people
he has the 4 pot kit from fastbrakes
ideal for me would be a 6 or 4 pot kit @ 13.6 w/ low dust pads
Old Mar 21, 2007 | 02:01 PM
  #37
ma_sha1's Avatar
More pods isn't necessary better.
OE comes with one pod. Should the wilwood 4pod
stops 4x better? No. Once you get above 4 pod, money should
go to bigger rotor.
Old Mar 21, 2007 | 02:08 PM
  #38
Neal376's Avatar
ugh....my head is begining to hurt
i just want a bbk!!!
why does this have to be soo complicated!
Old Mar 21, 2007 | 02:12 PM
  #39
KrazyEd's Avatar
When I am ready to purchase I am going Racing Brake 4 pot front ant OE rear BBK upgrade.
Old Mar 21, 2007 | 06:49 PM
  #40
ma_sha1's Avatar
Sorry, Neal, I was typing in a rush. I'll try to explain better.
The difference between 1 & 2 pod vs 4 pod is HUGE, Typical 1 &2 pod design has pods (pistons) coming from one side of the caliper only, pushing only the outside of brake pad/rotor & causing the back side of caliper to passively pressing the other brake pad to the back side of the rotor.
4/6 Pod caliper has pistons on both side of the caliper,
in 2+2 or 3+3 format. Therefore, the brake force applied to both side of the
rotor are even. This does not mean more clamping force, just more even pressure, even pad/rotor wear & more consistent long term performance.
6 pods may use 3 smaller pistons on each side vs. 4 pods = 2 bigger piston on each side, the total area of the piston contact surface for 6 pod may not be significantly bigger than 4 pod. The 6 pod caliper it'self may bot be much bigger than 4 pod caliper either, therefore a lot of times, they both fit the same size rotor. Bigger sized rotor matters more that two extra pods.
The difference between 1, 2 pod OE caliper vs. 4 pod Wilwood:
1, weight savings = performance
2, One side push vs. two side push = Performance
3, look & bragging rights
The difference between 4 pod vs. 6 pod wilwood caliper:
Just bragging rights, I.E. I've got more pods that you. They weight about the same, look about the same & perform about the same (Unless 6 pod gets bigger rotor).
In summary:
4 pod 13.6" BBK set up is better than 6 pod 13" BBK in both look & performance due to bigger rotor. The funny thing is, the 4 pod 13.6" may cost less than 6 pod 13".
Old Mar 21, 2007 | 09:31 PM
  #41
KrazyEd's Avatar
^^^very good explanation. Thanks. Cleared up some questions I had.
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
mushu
Jul 15, 2015 03:55 PM
