My steering wheel is shaking badly at high speeds
Old Mar 13, 2007 | 01:26 AM
osamabinwayne's Avatar
So my steering wheel shakes alot at speeds usually above 60+ It's strange though because sometimes it would shake and sometimes it would be fine. I've balanced the tires twice already so that couldn't be it. Took my car to the dealership to replace my rotors and brake pads and asked them to check it out for me and they told me the main cause of vibration was a bent rim. I've driven with a bent rim before and the steering wheel didn't even shake. Could it be something else?
Old Mar 13, 2007 | 01:45 AM
LightsOutG35's Avatar
Purchase Hub Centric Rings. This should help the vibrations tremendously.
Old Mar 13, 2007 | 02:20 AM
Aren't Hub Centric Rings for aftermarket rims? I have stock 17 inch rims. What size should I get and where whould I get one.
Old Mar 13, 2007 | 02:29 AM
Sorry, I did not realize you have stock 17" inch wheels.
Old Mar 13, 2007 | 02:45 AM
ttrank's Avatar
Grocery getter
I would have another shop look at your wheels and tires. You might have a bent rim.
Old Mar 15, 2007 | 07:09 PM
Paperchaser's Avatar
bent rim
bubble in one of the tires
get wheel alignment
has to be one of these 3
Old Mar 15, 2007 | 07:31 PM
Drewer's Avatar
add this to the "things to check" list. . .
If it does it when you turn especially, might be a bad wheel bearing.
Old Mar 16, 2007 | 10:55 AM
WheelsDirectOnline.com's Avatar
If it is not a bent wheel, More likely than not you have a tire issue. Do you by any chance have an aftermarket suspension?
Old Mar 16, 2007 | 02:47 PM
bossautosports's Avatar
You tire may be coming apart inside and something like that you will not even see until it blows out at 75mph and fu_k you day up !!!! I learned that lesson a few years back , it didn't turn-out too well for me !!
Frank
Old Mar 16, 2007 | 02:51 PM
617G's Avatar
CFW (Carbon Fiber Whore)
bent rim...happened to me...even though you can balance the tire, you WILL feel it...time for some aftermarket wheels
Luisgalvan33
Jul 19, 2018 08:16 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
G35OUTLAW6MT
Jul 13, 2015 02:26 PM
