Has anyone come across this strut bar before?
Old Mar 27, 2007 | 07:07 PM
  #166
ILLicit's Avatar
yepppppp, will post it in less than 5min.
Old Mar 27, 2007 | 07:09 PM
  #167
accordfreak's Avatar
hurrrrry!!!
Old Mar 27, 2007 | 07:20 PM
  #168
ILLicit's Avatar
POSTED
https://g35driver.com/forums/brakes-suspension/147656-circuit-sports-stut-bar-review.html
Old Mar 27, 2007 | 07:28 PM
  #169
Originally Posted by X-Vert
thank youuuuu!
Old Mar 27, 2007 | 07:57 PM
  #170
LjN_728's Avatar
Just ordered it! Damn wish there wasn't traffic going that way or else I would've picked it up myself and saved $20!
Old Mar 28, 2007 | 01:14 PM
  #171
G35JAMMER's Avatar
Just ordered one, I have a 03 coupe with a 5/16 spacer and the stillen ca. Should fit without the engine cover.
Old Mar 28, 2007 | 03:47 PM
  #172
Triji's Avatar
I ordered one as well... It should be here tomorrow... I have the Vortech SC and a SSV... I will let ya all know how fitment is.
Old Mar 28, 2007 | 03:57 PM
  #173
willthethrill's Avatar
Originally Posted by bustemupbob
Here is a few Close-Ups.
[IM
can you still adjust the shock or do you have to remove the bar each time?
Old Mar 28, 2007 | 11:35 PM
  #174
here's mine on the crawford
https://g35driver.com/forums/brakes-suspension/147912-circuit-sport-strut-bar-crawford-plenum.html
Old Mar 29, 2007 | 04:24 AM
  #175
aleok's Avatar
Does it look like there's enough room to fit the adjusters for coilovers?
Old Mar 29, 2007 | 11:15 AM
  #176
Gsedan35's Avatar
Depends on how much further the setup sticks up vs oem shocks.
As a FYI I measured 1/2" of deflection at 100lbs of force, tried to measure twist, couldn't imagineer a bankable test jic oh well.
Old Mar 29, 2007 | 12:40 PM
  #177
dubs's Avatar
I checked out my edfc motors & it will clear the mounts of the bar. All that has to be done is to unplug the wiring to the motors, snake the wiring through the opening on the bottom of the bar, & then bolt it down. Still on the fence with this. I think I will wait one more month & just buy the arc bar.... but for all the guys with a similar setup this will fit.
Old Mar 29, 2007 | 01:45 PM
  #178
dklau33's Avatar
So for us non engineer savvy people, is that good or bad? It seems to be quite a bit of deflection for only 100 lbs of force. Have you tried this bar out yet? Any initial impressions?
Old Mar 29, 2007 | 03:52 PM
  #179
bobshuai's Avatar
Bar clear or not able to clear aftermarket spacer?
Hi
I found out after Randy help me took out the engine cover. I think the circuit strut bar will clear 5/16" and pushing 5/8" spacer and here are 2 pictures.
Old Mar 30, 2007 | 04:43 AM
  #180
rockd's Avatar
Has anyone actually installed it with a 5/16" spacer? Will it fit with the engine cover on? How about with the engine cover off?
