Has anyone come across this strut bar before?
Old Mar 21, 2007 | 06:34 PM
  #121
Calvin's Avatar
Overglorified Altima
Originally Posted by skaterbasist
Thanks for the info.
Your right, it's a huge mistake that will make it lose customers like me.
I have a 5/16 spacer on order, so I guess its Richie for me.
yep, i was right about to cancel my order for that strut bar to get this CS one...until i saw that it doesnt clear.
Old Mar 21, 2007 | 06:37 PM
  #122
bobshuai's Avatar
Originally Posted by SFLG35
exactly what i was thinking
now need some pics of it over a crawford or without the cover on
send me your crawford and I will instal it and take some pictures for you.
Old Mar 21, 2007 | 06:38 PM
  #123
accordhybrd's Avatar
Has anyone confirmed that it will fit the sedan yet? If someone in Norcal has one and wants to test fit on my 06 please PM me.
Old Mar 21, 2007 | 06:40 PM
  #124
bobshuai's Avatar
Originally Posted by bustemupbob
Hey Bob,
Is there enough space for an coilover setup under those mounting points?
I think if I have time this weekend then me and aHero will find out for you. If I have time, because I will need to swap the bar to his car and see if it works with his coilover.
  #125
Calvin's Avatar
quoted from a few posts above.
Originally Posted by Phase 2
CS bar will fit both G35 coupe and Sedan
Old Mar 21, 2007 | 06:44 PM
  #126
bobshuai's Avatar
Originally Posted by GTT
Never heard of circuit Sport, is it a good brand
I thought about the samething but after I drove around, I think CS is a good brand especially the price I paid.
Old Mar 21, 2007 | 06:49 PM
  #127
bobshuai's Avatar
Originally Posted by FenixL1P
i had a slight problem with my ac line bracket during my richie stb install... i stripped the bolt holding the bracket down... i also broke the little white clip holding the ABS brake line to allow fitting the stb bracket flat against the strut tower area.... this is all on the driver's side... I can't even get to my d-spec adjustment ***** with the richie stb...
I'd think this new bar would have installation issues with all modded g's... whoever designed this bar didn't model all the possible outcome or potential upgrades that owners have put into their car.... it may be cheap but at the cost of preventing other mods from improving the cars breathing or suspension characteristics....
You gain some and you loose some, CS posted that their R&D was base on OEM Spec & Set up. There are few car's OEM strut bar need to be replace when the owner wants to upgrade the suspension.
Old Mar 21, 2007 | 06:56 PM
  #128
godmans's Avatar
Originally Posted by Jeff92se
Circuit Racing bar:
Richie bar on sedan.
Look at the thick mounts. If you have a sedan, you are going to have a hard time with this one.
Is the Circuit Racing STB made out of Aluminium or Stainless Steel?
Old Mar 21, 2007 | 07:01 PM
  #129
Jeff92se's Avatar
Red Card Crew
I'm sure it's all aluminum, judging by the color and the fat aluminum welds. I guess I'll have to change my mind a bit. If you look closely, it misses the ac mount that the richie bar slides under. But it also looks like you have to lose the green mount for this one to work.
Old Mar 21, 2007 | 07:06 PM
  #130
Calvin's Avatar
this is what phase 2 has to say:
I believe it's 6061 aluminum but I'll double check to be sure.
Old Mar 21, 2007 | 07:09 PM
  #131
I did see that, but seeing that they also stated that it fits the coupe with no adjustment to the A/C line and Bob had to move his A/C bracket I do not know how well I can trust there statement. (post #96)
I would like to see it installed on a sedan prior to my order for a new strut bar.
Old Mar 21, 2007 | 07:31 PM
  #132
accordfreak's Avatar
just ordered mine for the heck of it. I have the crawford plenum. Don't worry, you guys will have pictures on a new thread.
i don't understand why some of you people are so **** about losing the bracket haha your car won't explode, don't worry.
Old Mar 21, 2007 | 07:41 PM
  #133
Once Accordfreak gets the strut bar it will be tested fitted on my sedan with pictures.
Old Mar 21, 2007 | 07:43 PM
  #134
g35man04's Avatar
CLUB MODERATOR
SO im guessing there isnt a strut bar out there that can fit with the 1/2 MD spacer?
Old Mar 21, 2007 | 07:44 PM
  #135
Calvin's Avatar
richie strut bar fits..
Originally Posted by richie
The bar clears ALL current plenum upgrades on the market as well.
vrt strut bar fits..
