Suspension Problem...
Old Mar 23, 2007 | 10:19 AM
jclit's Avatar
Im not sure whats going on, but when ever I go over a bump or anything on the freeway it feels like my back end is jerking. I changed the springs myself about 1 1/2 weeks ago, ever since then its been doing it.I was driving down the freeway with my friend following me and he said that my tire was wobbling and it looked like it was going to fall off? DO any of you guys know what it could be? Maybe i left a loose bolt somewhere? Im not sure what it is, but it seems to be getting worse. I got an alignment like 3 days ago, and it didnt really help, in regards to the jerk/wobble in the back end..
Old Mar 23, 2007 | 11:01 AM
BadBoy06's Avatar
you better get this checked out ASAP.
Hopefully its nothing major..check your lugs
how many miles/year?
Old Mar 23, 2007 | 11:03 AM
jclit's Avatar
I checked lugs, 03 with 50k miles, im sure its something i didnt tighten...
Old Mar 23, 2007 | 06:14 PM
6MTFTW's Avatar
So, go back over everything and tighten everything again??
-Jerome
Old Mar 23, 2007 | 06:18 PM
jclit's Avatar
Well its pretty much just a couple of bolts you have to loosen, and they seem to be tight..
Old Mar 23, 2007 | 06:41 PM
Canadian's Avatar
Canada, eh?
Maybe try and go check the alignment again? Where did you get the alignment done?
Old Mar 23, 2007 | 06:46 PM
6MTFTW's Avatar
If the tire wobbles that much, either the wheel is extremly bent/warped, there is something loose, or the bearing is extremely worn out. I'm willing to bet that something is loose.
-Jerome
Old Mar 23, 2007 | 11:03 PM
BadBoy06's Avatar
bearing maybe? but needs to be fix
Old Mar 24, 2007 | 12:09 PM
deuceduzit's Avatar
Dude...I just noticed that I have the same issue yesterday....Let me know what you find out.
Old Mar 24, 2007 | 05:24 PM
deuceduzit's Avatar
I just got my car aligned an hour or so ago, I haven't experienced the problem yet, I'll keep you guys posted.
Old Mar 25, 2007 | 12:40 AM
jclit's Avatar
Originally Posted by andycon
What kind of springs did you put in?
when you did the rear springs, you dropped the swing arm - did you keep the torsion bar aligned. the correct procedure is to mark the torsion bar and then retighten in same position (not sure if i got thr right terminology here, it's either the torsion bar or swing arm brace - dont recall exactly)? your rear alignment may be way out of wack?
Also, check to make sure the springs are seated properly. they must sit in the spring seat (swing arm) properly.
Also, check your wheel nuts - did you cross-thread some nuts - so they appear tight but are not? look and see if the nuts are all the same depth.
Did you tighten the wheels off the ground, then retighten on the ground? if you just slammed it to the ground then tightened, you may have some loose nuts. Jack it up and retorque the nuts.
My vote is rear alignment.
Torsion bar? which bar is that? I Dont think i moved that bar, I only removed enough parts to remove the springs and camber arms...I got an alignment at a local shop, with the new hunter radar....
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
