I know its been asked 100+ times but.....
Old Mar 29, 2007 | 05:18 PM
edman911's Avatar
I have a '05 G35 Sedan 6MT w/ the sports suspension. From what I can tell '05 350z revised springs will work on the front and back of the car. The only problem I will have is becasue the spring rates on the revised springs are much high than the stock rear springs on the g35 sport suspension. Is that right? With the higher spring rate in the rear how will the car behave?
Can put on all revised spring for a while and not damage the car? Or should I put the 350z springs on the front and add something diffrent to the rear? I am only looking for a 1'" drop all around, and I want it to be level. thanks.
Old Mar 29, 2007 | 05:51 PM
G SEDAN's Avatar
from what i have always understood the G35 sedan sport suspension is the same spring rate as the 350z. (unrevised, someone chime in on revised) The rear will appear to sag a lil more than the front that is why a lot of people put Z springs front and Coupe springs rear.
Old Mar 29, 2007 | 05:59 PM
trey.hutcheson's Avatar
The revised rear springs require the revised rear shocks, though to my knowledge one could use the shocks off an 05+ coupe with the sports suspension. I'm no suspension expert, but I've read that using the revised springs on the stock sedan sport rear shocks will result in the shocks bottoming out - maybe Gsedan35 will chime in.
Old Mar 29, 2007 | 06:07 PM
edman911's Avatar
so basically the fronts are okay. When you say bottom out, you mean break?
Also when you say coupe you mean, g35 '05 coupe rear springs? Is that correct? Will i still get the 1" drop in the rear
Old Mar 29, 2007 | 06:43 PM
Truth's Avatar
I just picked up some Coupe HTech springs and the sedan sport shocks, how will this combo work. I'm having a hard time understanding the answers I get after searching.
Old Mar 29, 2007 | 06:48 PM
Jeff92se's Avatar
Red Card Crew
That's because there should be a sticky here in the sedan section that details it.
Old Mar 29, 2007 | 06:54 PM
dklau33's Avatar
To the OP, just get a set of the revised OEM shocks and springs from a Z. Install will be easier since you won't have to swap the front springs. Plus it's cheap since you should be able to get a set for under $200.
Taken from the sticky...
Oem springs
G35 coupes with oem 17’s & 18’s
G35 sedan’s with sport suspension
350Z’s 2003/2004
Front:314 Rear:342
Oem springs
G35 coupes 2005/2006 with oem 19’s only
350Z 2004.5 to 2006
Front:314 Rear:427
Old Mar 29, 2007 | 07:03 PM
Truth's Avatar
Oem springs
350Z’s 2003/2004
Front:314 Rear:342
Oem springs
350Z 2004.5 to 2006
Front:314 Rear:427
??? What does that mean?
Old Mar 30, 2007 | 02:31 AM
G SEDAN's Avatar
those are spring rates for the Z/G's. As you can see, 03/04 was a direct swap. 05/06 is not. I have some unrevised Z rear springs for sale if you are interested PM me.
Old Mar 30, 2007 | 09:54 AM
edman911's Avatar
I am assuming from the increased spring rate on the revised 350z setup that the rear of the car is going to be much stiffer, but the front will be the same? Is the higher number mean a "less springy" spring? LOL Sorry for the layman terms.
Old Mar 30, 2007 | 11:55 AM
darnelled's Avatar
Yes, it will be stiffer. You could also go with springs from an 03-04.5 350Z placed on your current shocks for a spring rate that os closer to you current set-up.
Old Mar 30, 2007 | 12:54 PM
Truth's Avatar
So how will 05 Coupe HTecs work with the OEM sport shocks? Arent HTechs non sport springs? They are softer correct?
Old Apr 5, 2007 | 04:41 PM
Gspott's Avatar
Eibach Pro Kit..??
Well, how about just not having to worry about this issue at all (combining springs) & throwing on the Eibach Pro Kit..??? A great investment for the $$. Great in the corners & smooth thru the straights
Old Apr 5, 2007 | 04:55 PM
BadBoy06's Avatar
that and camber kit..call it a day
chinee
Jun 10, 2024 07:48 PM
neight
Accessories
Jun 29, 2020 12:24 AM
bu villain
19 Inch
Nov 15, 2015 09:23 PM
