Help! Got VDC/Slip lights after pad change
Old Apr 7, 2007 | 10:28 AM
gtv630's Avatar
and front bleed. Everything seems ok and I tried resetting ecu by battery disconnect but no luck. Tried searching but haven't had luck sorting to any thing useful. Car is 2004 G35 sedan.
Old Apr 7, 2007 | 12:32 PM
Calvin's Avatar
Overglorified Altima
check your brake fluids
Old Apr 7, 2007 | 12:43 PM
ttrank's Avatar
Grocery getter
^+1
Old Apr 8, 2007 | 03:29 PM
n1cK's Avatar
G35 6MT
if you bleed the front, bleed the back. make sure you follow the bleeding order. the FSM also states that before bleeding, you should disconnect the neg. battery terminal (or the VDC module). when your done bleeding, plug it back in.
Old Apr 9, 2007 | 05:21 PM
gtv630's Avatar
Seems to have remedied itself after a few stops and starts. I'm not sure why but they are off now.
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
mjfenix
Jul 24, 2015 05:16 PM
ClwMike
Jul 23, 2015 12:55 PM
myaso
Lighting
Jul 22, 2015 10:34 PM
