Lowering the G?
Old Apr 7, 2007 | 08:09 PM
Mad Paradox's Avatar
J-Dizzle
Lowering the G?
Hey all,
I'm planning on doing clean drop, I'm not dropping it to the lowest setting. Perhaps a finger gap all around, does this require me to use a Camber kit? I don't mind running some negative camber. Reason I am concerned is that I purchased GT SPEC underbody bars and specifically the rear lower tie bar has a hard time fitting with a SPC camber kit install. Any comments will be greatly appreciated.
Old Apr 7, 2007 | 08:34 PM
Andy2434's Avatar
Hmmm . . . At about 1 finger gap you will have lowered your car approximately 1". You will have picked up a bunch of negative camber. I have been hesitant on getting the GT Spec products for the very same concern, which you have. I have read that some people have been able to install the GT Spec bars and have had no issues in conflict with the SPC camber/toe set-up.
Old Apr 8, 2007 | 01:54 AM
J-Dizzle
From what it sounds like to me, you just need a longer bolt to fit both the bar and the SPC Camber arm. Let's hope that is the case. I see, okay thanks andy for your response.
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
DRG35R
Jan 31, 2016 07:14 AM
