help to install rear rotors (brembo)
Old May 1, 2007 | 06:11 PM
White03G's Avatar
i'm trying to figure out how to remove the rear rotors.
I removed brake caliper & have hand brake off. Anything else? Since the rotors refuse to leave.
Thanks!
Old May 1, 2007 | 06:42 PM
MeetJoeAsian's Avatar
make sure you do not leave the parking brake on...
and if they don't come out, use a rubber mallet and knock them out...
thread:
https://g35driver.com/forums/brakes-suspension/153504-diy-request-rotors.html
Old May 1, 2007 | 06:44 PM
jjyellow's Avatar
Get a rubber hammer and beat the sheit out of it and it will come off
Old May 2, 2007 | 04:30 PM
tekknikal's Avatar
what they said. dont use your brakes or ebrake!!! it will come off.
Old May 2, 2007 | 11:06 PM
Gilley's Avatar
If rubber mallets don't work, you may need a heavier hammer. Turn the rotor as you hit it from the back.
Old May 3, 2007 | 12:03 AM
bikinilust's Avatar
Dude... Isnt the rear rotor on the Brembo setup different than the stock set up I'm almost positive there is a huge nut in the center holding that rotor on... Please correct me if im wrong
Old May 3, 2007 | 12:10 AM
PsYcholG35's Avatar
Who me??? NAAAAAAA.
DO NOT TOUCH THE BIG SCREW IN THE MIDDLE thats a big NO NO. thats connected to the LSD/CV shaft it self.
Old May 3, 2007 | 11:14 AM
Gilley's Avatar
The Brembo and non-Brembo calipers and rotors go on and off the same way, but not by using a big nut in the middle. Two bolts hold each caliper and the rotors are held on the hub by the wheel and lug nuts (and the caliper keeps it from coming all the way off). Sometimes rust will cause older rotors to be resistant to removal from the hub.
Old May 3, 2007 | 06:51 PM
bikinilust's Avatar
Oooohhh Man .. Thanks guys
silencedeyes
Brakes
Nov 26, 2015 05:36 PM
MikeTanabe
Brakes
Aug 26, 2015 03:02 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
