View Poll Results: What is the best coilover system for under $1100?
Tanabe Sustec SOC2
7.41%
Tein Basics
31
57.41%
Ksport Kontrol Pro
3.70%
Blitz TR-1
1.85%
Just get Tokico D-Spec Shocks and a Good Spring
18.52%
I know another kit you can get that is better than those for under $1100
11.11%
Voters: 54. You may not vote on this poll
Which coilover system for under $1100 ?
Old May 9, 2007 | 10:58 PM
Calvin's Avatar
Overglorified Altima
It doesn't really seem like you have a strong grasp on suspension and handling based on the number of questions asked, so the tein basics would be your best bet. No adjustments needed for the dampening, just height, and they are cheap enough that you can purchase camber kits for the front and rear, becasue you WILL need them.
i completely agree. tein basics are just that - basic. as redlude put it, you don't seem to have a strong grasp on suspension and handling. with the basics, all you'll have to worry about is height adjustment - which is fairly simple and shops will not charge much if you don't want to do it yourself.
Old May 9, 2007 | 11:01 PM
Concealed StrateG35's Avatar
but compared to my stock sport suspension set up are they a lot better??
Old May 9, 2007 | 11:02 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
they are worlds better than stock.
-GP-
Old May 9, 2007 | 11:04 PM
Calvin's Avatar
stiffer - yes. handling - yes.
comfort - depends on what you define comfort as. personally, i find the stiffer ride very comfortable. but the girls hate the ride...lol
Old May 10, 2007 | 12:04 AM
ok now i need to know poll the people who have tein basics WITH 20" wheels to see what they have theirs set to, cuz i know the shop won't spend time trying to get the right drop without me paying them lots of $$$.
Old May 10, 2007 | 02:38 AM
nate4598's Avatar
Originally Posted by ttrank
Tein is the coilover of choice for this forum so most people will vote Tein. I have the CS with EDFC and am very happy with them.
Hi ttrank...what's your dampening setting for both front & rear. I also have CS but without EDFC therefore I want the best setting for comfort & handling so I just adjust them at once. I currently have the front somewhere in the middle & the rear about 4 level from stiffest
Old May 10, 2007 | 02:45 AM
Skaterbasist's Avatar
Retired SuperMod
For under 1000, its Tein Basics for sure.
With just Tein Basics, Camber Kit, Sway Bars, & Strut Bar, you will have superb handling compared to stock.
Good enough for the occasional tracker too
Old May 10, 2007 | 02:58 AM
When installing the coilovers, do you need to mess with the sway bars too? or is that different? Because I'm going to have the shop do everything and if you don't need to take the sway bars out anyway to install then i don't want them messing with it because they will charge TOO much. But if they do i'll get some sways
Old May 10, 2007 | 03:18 AM
Retired SuperMod
Sway bars and Coilovers can be done seperately, as they are not directly connected.
You or someone else can install either one, without tampering with the other.
Someone correct me if im wrong, but im 99% sure of this.
Old May 10, 2007 | 03:37 AM
MechEE's Avatar
I've researched in a similar price range myself, and I came to the conclusion of the Stance coilovers with the OEM-style rear (rather than the true coilover rear setup). They're a bit stiffer than the basics (12k/11k springs rather than 9k/9k), but they have 15-way adjustable monotube dampeners. They're ~$1150 shipped. I also went with camber kits front and rear (SPL and SPC respectively).
Old May 10, 2007 | 04:46 AM
Hmm What do you guys think about these? Anyone else has this? Comments?
Old May 10, 2007 | 04:47 AM
How much do you think a shop will charge to install sway bars? Is it difficult to install? Does it take long to install?
Old May 10, 2007 | 11:12 AM
Calvin's Avatar
50-75 bucks.
Old May 10, 2007 | 02:25 PM
Retired SuperMod
Not sure, but what hero stated seems accurate.
But why pay 50-75 when you can do it yourself?
Well, atleast I will.
Old May 10, 2007 | 02:36 PM
  #30
izmir41500's Avatar
G35driver Addict
it's easy if you have the right tools. i couldnt break the bolts loose
but i had everything else.
have you seen this thread: https://g35driver.com/forums/brakes-suspension/65190-g35-350z-aftermarket-coilover-springs-shocks-spec-s-w-updates.html
there's a ton of info in there.
I was thinkin about the stance then I read:
Stance coilovers (Monotube, true coilover in rear, 15 way adjustable dampning, full height adjustable
Spring rates 672/280*
*since rear springs are run on coilover body, they leverage more spring power to the rear wheel. To get the same spring power to the rear wheel as a 280lbs spring in the OEM location you would have to use a 448lbs spring.
CAUTION: Really good owner review's exist and at $1150 shipped they are a excellent value. But a number of owner's are experiencing issues with the lower shock mount bushing not being designed to carry the loads being asked of it since the oem setup was not designed to have the springs with the shocks. A new sperical bushing fix has been talked about, but hasn't been produced yet. One could alway's convert to a 448lbs spring setup in the oem location and avoid the whole issue.
