View Poll Results: What is the best coilover system for under $1100?
Tanabe Sustec SOC2
7.41%
Tein Basics
31
57.41%
Ksport Kontrol Pro
3.70%
Blitz TR-1
1.85%
Just get Tokico D-Spec Shocks and a Good Spring
18.52%
I know another kit you can get that is better than those for under $1100
11.11%
Voters: 54. You may not vote on this poll
Which coilover system for under $1100 ?
Old May 9, 2007 | 08:32 PM
Concealed StrateG35's Avatar
Ok guys I'm still trying to decide between springs and coilovers. So far some people have told me to stay away from tein, but then again a lot of people have them and they love them.
So I'm wondering what do you think is the best coilover system for under $1100 ???
Please don't pick one just because you have it, If you pick it it's because you honestly, truly think it's the best by what you have heard/read, specs, experience, etc.
When voting, ask yourself this question:
If someone told me that I could get ANY OF THOSE for free, which one would
I pick based on the specs/reputation/quality/handling ?
I can't add options to the poll but I also found these for under $1100
1. D2 Racing Sports RS Coilover System
2.Megan Racing Coil-Over Dampers
Old May 9, 2007 | 08:40 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
The Basics are the cheapest out of all of those coils and IMO the best. Not just because i have them. If you dont need dampening adjustment then i'd say get the Basics and use the extra money for another mod. They arent too hard and arent too soft, right in the middle, they're perfect.
-GP-
Old May 9, 2007 | 08:42 PM
redlude97's Avatar
It doesn't really seem like you have a strong grasp on suspension and handling based on the number of questions asked, so the tein basics would be your best bet. No adjustments needed for the dampening, just height, and they are cheap enough that you can purchase camber kits for the front and rear, becasue you WILL need them.
Old May 9, 2007 | 08:44 PM
good point on the camber kits, that totally slipped my mind... even better reason to get Basics.
-GP-
Old May 9, 2007 | 08:48 PM
-GP-
So i will need FRONT and REAR camber kits?
What is the cheapest price you have heard on the Tein Basics ? I got a price of $760 shipped, does that sound GREAT, or could I get a better price you guys think?
Old May 9, 2007 | 08:49 PM
izmir41500's Avatar
G35driver Addict
it doesn't matter that much if you're not gonna push your suspension on the track. look for something that suits your riding comfort or sportiness. I'd say the Dspecs and a good spring will do you just fine. And if you decide to go lower than 1" with the springs you have plenty left over for camber kits.
Old May 9, 2007 | 08:51 PM
So the reason why I want coilovers is because I don't want to get some springs and them have them lower too much and I rub. (i have 20x9 fron and 20x10 rear)
redlude97's Avatar
Depends on your drop, I would say yes if your total budget is $1100, Basics=$7-800, rear eibach $143, front eibach $385 =~$12-1300. If you are sure you won't drop more than 1", you can probably get away with just the rears
Old May 9, 2007 | 09:02 PM
My budget is $1100 on just coil-overs, I have extra for camber kits if needed
Old May 9, 2007 | 09:08 PM
redlude97's Avatar
I would still recommend basics, I don't think you'll know how to properly adjust the dampening, so why have that function. They'll do the job and are good for 80% of the people on this board looking for coilovers. You said yourself that you just don't want to drop too low so you won't rub.
Old May 9, 2007 | 09:16 PM
That and i want something that performs and feels better than stock, I wont' know how to properly adjust the dampening but a shop would, right?
Is there anyway to adjust a coilover electronically?
Old May 9, 2007 | 09:22 PM
ttrank's Avatar
Grocery getter
Tein is the coilover of choice for this forum so most people will vote Tein. I have the CS with EDFC and am very happy with them.
Old May 9, 2007 | 09:26 PM
redlude97's Avatar
The basics are stiffer than stock and the dampening is already matched. Most shops will not know how to adjust dampening for best performance except for a select few which WILL charge alot. Setting dampening correctly requires alot of seat time and adjusting, and more seat time. There are electronic kits, but not in the $1100 range, closest being the tein flex's/cs's with EDFC, but still you won't really know what you are doing and won't see any benefit from it.
What's the difference between quality/performance/comfort between the basics and the ones that you have?
Old May 9, 2007 | 09:54 PM
For the tein basics it says it uses oem upper mounts, is it better to buy aftermarket ones or just go with oem?
toe kit/camber kit/a-arms are all these the same kits!? just different names?
If they are not the same, how will i know if i need a-arms compared to camber kits? or toe kits?
