**Experts Wanted** How do my alingment specs look?
Old May 17, 2007 | 11:36 AM
ron4row2's Avatar
Question **Experts Wanted** How do my alingment specs look?
I recently installed sedan suspension with the Coupe/Z spring setup. I also upgraded to the OEM 18" wheels with 245/40/18 tires. I purchased the lifetime alingment from Firestone and here is what I'm at.
Front Left
Camber -1.0
Toe .07
Front Right
Camber -1.5
Toe .06
Rear Left
Camber -1.2
Toe .14
Rear Right
Camber -1.3
Toe .05
I'm going to buy the SPC rear kit for the camber & toe. How bad to I need to get a front camber kit?
Old May 17, 2007 | 01:09 PM
Q45tech's Avatar
If tire wear is any consideration the cambers should be -0.7 degrees max and side to side should be equal within 0.2 degrees [with your weight in drivers seat]...........your weight will drop drivers side 1/4-1/2" which will increase negative camber by 0.2-0.4 degrees on left side front and rear.
Old May 17, 2007 | 02:31 PM
ron4row2's Avatar
So right now I'm screwed!!! I will need to get a front kit.... I just ordered a rear SPC kit, which will fix that. The front ones are so freaking $$$$$
Once I get the front and rear kit what should I be shooting for in regards to camber and toe?
Old May 17, 2007 | 03:09 PM
Deezflip's Avatar
The rear toe specs seems off by a good amount.
Old May 17, 2007 | 08:28 PM
ron4row2's Avatar
I noticed that. I'm getting the spc kit for the rear. How bad are the Front.
Old May 19, 2007 | 12:10 PM
EricIsKlumzyee's Avatar
they dont look that bad.. looks like you took a good drop?
SPC kit should fix everything
you should've seen the camber on my old car ._.
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
