My car is missing a "brake hardware kit"
Old May 17, 2007 | 12:44 PM
GuyLegend's Avatar
Can someone tell me what exactly a brake hardware kit is? Long story short, I had my brakes serviced (pads and rotors) at a local good year shop (since the nearest Infiniti dealership is 100+ miles away).
Anyways, I've been getting a lot of brake noise so I decided I would go straight to Infiniti. They said you need to back to Good year and have them install a "brake hardware kit", something of which wasn't installed according to Infiniti. The quick explanation from the Inifiniti service guy was that it's a spring and some other parts.....
So can anyone tell me what it is?
Old May 17, 2007 | 01:06 PM
Q45tech's Avatar
Noise and thermal insulation shim plates plus end clips that hold pads in place.
Shops [ill trained minimum wage] throw them away since they don't fit properly on their copy cat kinda fit pads.
Old May 17, 2007 | 01:38 PM
GuyLegend's Avatar
Wow, thanks for the explanation. Nose and thermal.....guess that explains the brake noise and excessive wear that had rotors machined after only 3000 miles.
Old May 18, 2007 | 10:05 AM
Q45tech's Avatar
Brake noise [squeel and groan] is caused by pads vibrating in caliper and modes of rotor vibration.
Brake pads are tested in oem assembly then shims selected to minimize noise.
http://www.vibrationdata.com/Newslet...ust2006_NL.pdf
http://www.inwoodauto.com/proinstall...pdf/TB5000.pdf
itschuckster
Jul 25, 2015 08:07 AM
Karnicle
Jul 23, 2015 05:08 AM
tehmoonrulz
Jul 19, 2015 10:44 PM
mjfenix
Jul 17, 2015 02:07 PM
mushu
Jul 15, 2015 03:55 PM
