Rear brake problem
Old Jun 3, 2007 | 06:35 PM
cooldog45's Avatar
Rear brake problem please help!!!
I did my rear brakes recently and had a hell of a time getting the caliper bolts out because one side totally rusted in and the other had on bolt rusted. I got new pins and a new boot kit. I put everything together and noticed that the driver side caliper piston is torn. I also notices that the caliper pin that had the tinny rubber donut on the end of it does not allow the pin to go completely inside the bracket. I cleaned the bracket out and made sure there was nothing in it. After putting the driver side caliper on I drove on it for a little and noticed that the brakes are locked up. The caliper bolt is forcing the pad to continuously apply pressure to the rotor. I took it apart and took the donut ring off for now until I can get it to a shop. Now I guess my main question is: Will the dealer replace the caliper and the bracket under and expanded warranty? Also since the pads and rotor are fried will they replace those too if I say it's because of the faulty bracket?
the rotors, pads, pins and boot kit are all after market.
thnx for any input.
Old Jun 4, 2007 | 08:11 PM
Q45tech's Avatar
Using aftermarket pads and rotors plus pins and boots [+ tampering] should totally release Nissan from any obligation concerning calipers or their repair or replacement.
Sounds like your choices overheated the calipers.
Old Jun 4, 2007 | 08:37 PM
nghiars's Avatar
i agree with Q45tech
Old Jun 6, 2007 | 11:09 AM
cooldog45's Avatar
I dropped the car off at the dealer and they said the extended warranty will cover the caliper but nothing else. So I have to wait 2 days for the caliper to come in and get it on.
mike730
Jan 12, 2018 04:25 PM
atk08
Jul 30, 2015 03:12 PM
wojowojo16
Jul 27, 2015 09:57 AM
Lsantana757
Jul 20, 2015 09:08 AM
emorehs
Jul 17, 2015 09:45 AM
