Camber kit question
Camber kit question
Alright, so i'm getting some Tein H.Spec lowering springs for my coupe.. -.6 front, -.3 rear
so, do i need to get a camber kit for the rear? what about toe kit? or both? i dont know what to get! lol
Originally Posted by izmir41500
not necessarily. get your alignment first and see if you're in spec before you get a camber kit. the rear camber kit/toe bolts is $140 from spc.
http://cgi.ebay.com/ebaymotors/ws/eB...1943&rd=1&rd=1
it says rear camber toe kit but then the pic only shows the bolts...
where can i get the entire kit for 140?
do i really need both or can i get just the camber kit?
much thanks
buy the rear camber kit...it's only ~150 bucks and it'll pay for itself in the long run.
go with eibach or spc, whatever is cheaper at the moment. they're the same thing.
you'd want to be able to adjust both camber/toe...
depends on your drop and alignment. every car is different. you may or may not need it.
mine is only a .6 drop in front and .3 in rear... some said it would save me in the end.. i just need to find a kit thats less than 160 preferably
Originally Posted by aHero4Eternity
160..190...ain't that big of a difference. if you can't afford the difference in price, maybe you should be holding off on this project for a month or so.
i just prefer to save as much because im sure most people kno itll add up in the end.. some said they seen it for 140, so im hoping someone could point me in that direction.. thats like 30% off others at 190+9s/h!
ajusa.com, search under a nissan 350z
cool thanks... i see the arms for 146 which is nice, but do i need the toe kit as well or should i buy that after they try to align it and cant get it all the way/?
