Eibach Pro Kit Or S Tein????
Old Jun 13, 2007 | 01:48 PM
OverdriveG35's Avatar
Question Eibach Pro Kit Or S Tein????
What do you recomend for springs Eibach pro kit or S.tech kit? Has anybody heard of Zenn springs?
Old Jun 13, 2007 | 02:05 PM
Calvin's Avatar
Overglorified Altima
what are your goals with lowering springs? how important is a comfortable (soft) ride to you?
Old Jun 13, 2007 | 02:53 PM
Question Eibach Pro Kit or S Tenn????
Looks and handling are my goals when purchasing lowering springs. As far as the soft ride, i have 255/35/20 on the front and 285/30/20 on the rear and it rides hard. Even with the stock 19's it rides hard.
Old Jun 13, 2007 | 03:21 PM
EEjiggapin0's Avatar
do you want something that rides more stiff or a little softer than stock?
Old Jun 13, 2007 | 03:27 PM
redlude97's Avatar
the s-techs are stiffer than the eibachs, so will provide better handling. They are also linear in the rear, while the eibachs are progressive all around which will lead to more body roll before they stiffen up
Old Jun 14, 2007 | 01:33 AM
Gsedan35's Avatar
Your oem spring rates
314/427
Eibach G35 Coupe progressive springs 1.1”/1”
Spring rates in LBS initial/final front 229/337 initial/final rear 274/463
Tein S-tech G35 coupe 1.2"/.9" (fronts are progressive, rears are linear)
Spring rates in LBS 358/274 (final rates only, softer intial front progressive rate unknown)
Based on what you want I would drop with either of the following
Tein S-tech 350Z springs G35 coupe drop 1.2“/.1.1“ (fronts are slightly progressive, rears are linear)
Spring rates in LBS 386/402
Swift 350Z linear springs G35 coupe drop 1.3”/.1.1”
Spring rates in LBS 336/364
Old Jun 14, 2007 | 02:02 AM
Skaterbasist's Avatar
Retired SuperMod
I see coilovers in your future
Do it right the first time. It's worth it!
Old Jun 14, 2007 | 02:09 AM
Tarheel's G's Avatar
^+1. I have the Eibach's and am currently looking to purchase coilovers. Wait...forget I said that, do you want to buy some sweet springs from me?
Old Sep 5, 2007 | 11:40 AM
mt7rabbit's Avatar
I'm looking for the same kind of setup, I have an 05 coupe with 20's 245/35F & 275/35R. I'd like to stay close to the stock ride but I don't want to go softer and also I like the idea of the rear linear setup.
So my best guess is to go with said previous:
Tein S-tech 350Z springs G35 coupe drop 1.2“/.1.1“ with spring rates in LBS 386/402. Do I also need coilovers? and what kind?
thanks
Old Sep 5, 2007 | 03:21 PM
j-ondemand.com's Avatar
you don't need coilovers if all your doing is springs.But some aftermarket springs can kill your factory dampers. Like said above get coilovers. there adjustable you can also get some with custom spring rates so you get them as soft as you want.Coilovers do them once do them right no issues and no hassels. well theres my two cents
martin
Old Sep 5, 2007 | 03:22 PM
double post my bad
reavensf
Sep 17, 2015 11:30 PM
Machine Head
Sep 4, 2015 07:22 PM
mikemf8
Sep 3, 2015 08:01 PM
kevintandmd
Sep 3, 2015 06:41 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
