Getting H-tech's... now what?
Ok, so i've gone ahead and ordered some Tein H-spec springs for my coupe... .6 front, .3 rear.. when should i get a camber kit for the rear put on, if at all?
and is there anything else that I should get to help reduce any wear on my tires/car?
thanks!
thanks!
you can wait until after you get an alignment (which should be a couple weeks after the spring install - so as to let them settle) to see how far outta spec you are. but imo, that'll be a waste as you'll need another alignment after you get the camber kit.
just get it now and install it at the same time you install your springs. hopefully, you'll get some slack on labor and you can have everything aligned correctly the first time.
neffster
Jan 21, 2005 11:03 AM
