Your spacer opinion?
Old Jun 23, 2007 | 08:54 AM
cor72vette's Avatar
Does anyone know anything about these spacers? Good? Bad? No opinion? TIA!
http://www.tcsportline.com/categories.php?Cid=239
Old Jun 24, 2007 | 01:50 AM
redlude97's Avatar
what size spacers are you looking for and do you want spacers that bolt over the stock studs or replace the stock studs? Did those +35 wheels not work out for you?
Old Jun 24, 2007 | 01:05 PM
cor72vette's Avatar
Doesn't matter if to me if I use new studs or the spacers bolting over. The 35 offset did what I thought... brought the wheels in a little much. So I'm going to play around with some 5mm and 10mm spacers. Obviously, I'll play with the 5mm first so I don't have to pop out the studs. I'll sell the pair I don't like. The BFG 285's caused the issue. A 275 probably would have fit perfectly, but BFG doesn't offer the new KDW in that size. I really do like the look of the tires. They are meaty!
Old Jun 24, 2007 | 02:35 PM
redlude97's Avatar
Any brand 5mm spacer will work fine, a 10mm spacer will require replaceable studs I believe, as ichiba is the only brand that offers a 10mm spacer. To run a bolt on type spacer, you have to check your wheels to see if they have pockets to accept the extra length of the stock studs.
Marlin84
Apr 1, 2020 12:52 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
w4kj4k
Oct 2, 2015 07:57 PM
