can I put the SPC Bolts on to the Rear camber arms?
I put them on my car. Be warned you will need an aluminium carbide bit, some type of tool to spin the bit fast enough, and a bit of disassembly of the rear suspension.
If you brought it to my shop I'd have to get about $160 for the install and $80 for the alignment.
labor and alignment is fine I can do that myself.. just wanted to know if it'll work
thanks for the quick replies.. going to do this on saturday
- Eric
- Eric
Nope I need more negative camber adjustments..
Working on my show/track car..
IMO I'd prefer the bolts myself as the arms are harder to work with from under the car.
bolts will give me a quick easy adjustment at the track/home..
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
