Grinding sound when braking(sounded like the ABS check)
Old Jun 29, 2007 | 01:25 AM
cloud's Avatar
Today to avoid a car I had to swerve into a junction at high speed and when braking there was a grinding sound like when you startup the car drive 10mph and the car does that abs check grind.
Is this normal? Or is it the sound of ABS working? afaik abs doesn't make noise when its working? I thought it just pulsates?
Old Jun 29, 2007 | 08:58 AM
Noremac's Avatar
Absolutely. It could have been ABS or VDC (which uses ABS per wheel).
Old Jun 29, 2007 | 10:41 AM
cato's Avatar
SouthernComfort Moderator
Every time my Anti-slip kicks in, it sounds like a grinding noise. I think you are OK.
chinee
Jun 10, 2024 07:48 PM
3000vr4tt
Media Share V36 Sedan
Jan 4, 2023 03:20 PM
chinee
Aug 8, 2015 10:11 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
