Car swaying too much!!!!
Old Jul 2, 2007 | 10:11 AM
ORANGEBSRT's Avatar
heres the deal...I have an 'o6 sedan lowered on Tein H-tech for the 350z. I got kinetix camber and toe arms from a buddies coupe. I installed the arms, did the alignment, went for a drive, and now my car feels like its all over the place!! I doubled check the sway bars, those weren't even touched on the install. Went drivin on the highway....and it feels like no sway is there! The back end feels "squirly". I NEED HELP DIAGNOSING!!
Is it true that sway bar links go bad on these cars cause I called my advisor at infiniti and he told me he's never heard of links going bad.
Old Jul 2, 2007 | 10:20 AM
izmir41500's Avatar
G35driver Addict
sway bar links can go bad with aftermarket sways which are stiffer. there was one thread where the sway bar broke i think. get under the car and check your end links.
Old Jul 2, 2007 | 10:24 AM
ORANGEBSRT's Avatar
but it's the factory sway bars!!
Old Jul 2, 2007 | 11:32 AM
erdog's Avatar
Did your kinetix camber arms break? Some have reported that those break.
Old Jul 2, 2007 | 12:40 PM
ORANGEBSRT's Avatar
nah still good....I think I have to re-align the car to get more negative camber in the rear cause the factory spec is negative camber in the rear.
Old Jul 2, 2007 | 12:50 PM
kenchan's Avatar
sounds like you don't have enough toe-in on the rear. also your damp
rate is too low. also your swaybar needs to be upgraded to something
stiffer.
try fixing it in that order.
Old Jul 2, 2007 | 03:28 PM
gqraverice's Avatar
Are you on stock shocks? A car will sway if the shocks are bad....
Old Jul 2, 2007 | 04:08 PM
ORANGEBSRT's Avatar
How is that possible?
rezendvous420
May 31, 2020 01:26 PM
Sepsis
Feb 12, 2020 02:05 PM
marsman328
Northern California
Aug 11, 2015 07:29 PM
itschuckster
Jul 25, 2015 08:07 AM
vstypicals
Jul 20, 2015 10:55 PM
