Newbie: Springs or Coilovers?
Old Jul 28, 2007 | 01:51 AM
KapVu's Avatar
Just got a 2003 G35 coupe. Its stock and I like to setup the suspension before I do anything with performance.
I used to have an Acura TSX and it was said that that if i got springs, the struts would eventually give out and I would have to replace them, so it was worthwhile to just get coilovers. I'm curious, is the G35's the same way. The car has about 30G mileage and if I just installed aftermarket springs on stock struts, how long will my struts last, or would they eventually give out?
Also, do I need a camber kit?
What springs do you guys recommend for a nice drop (1.5" drop) that will not make the ride toooo bouncy? Thanks for all the help in advance!
Old Jul 28, 2007 | 02:05 AM
scott1026's Avatar
well, you should be able to find almost everything what you're looking for regarding springs and shocks using the search function. g/L with your findings
Old Jul 28, 2007 | 02:36 AM
KapVu's Avatar
Yes I did. Just searching I think I might go with the Tein Basics with SPC camber kits.
Will I need the camber kit for the front though?
Old Jul 28, 2007 | 03:45 AM
Calvin's Avatar
Overglorified Altima
need a camber kit? eh.
depends how low you drop the car....
but since the front isn't adjustable, as long as you drop it..you wont be as close to factory specs...
most live without a front kit, tho. then again, most aren't that far outta spec in front.
Old Jul 28, 2007 | 04:01 AM
by15vc's Avatar
go with coils if you like the flexibility of adjusting your ride height. if you're pretty set on how low you wana go, then you can get springs...but if it were me i would still stick with the coils since once you go rims or a kit, you might want to play around with your ride height...
Old Jul 28, 2007 | 11:16 AM
KapVu's Avatar
Aren't the basics not adjustable? I thought the basics are a set height.
Thanks for all the info.
Old Jul 28, 2007 | 12:07 PM
Calvin's Avatar
huh? that's the point of getting coils.
they are height adjustable only. you can't change the damping settings, however.
Old Jul 28, 2007 | 12:09 PM
KapVu's Avatar
that's right.
Where are some legit sites to buy aftermarket parts for the G35?
Old Jul 28, 2007 | 12:21 PM
Calvin's Avatar
try some of our site sponsors and check out the vendor classifieds..
Old Jul 28, 2007 | 11:57 PM
KapVu's Avatar
Is it safe to drive on aftermarket springs on stock shocks for a long period of time. Say over, 50,000+ mileage?
Wouldn't the car begin to sag or would the stock shocks eventually give out?
Old Jul 28, 2007 | 11:58 PM
Calvin's Avatar
the stock shocks are going to blow quicker.
Old Jul 29, 2007 | 12:05 AM
fais's Avatar
I was looking up the specs on the Basics on the Tein website and had a question, when they say:
FRONT
Height Adjust Range
Max/Min(mm/inch)
-40.0 / -1.57 to -93.1 / -3.67
REAR
Height Adjust Range
Max/Min(mm/inch)
-1.0 / -0.04 to -35.9 / -1.41
Does this mean the front will be dropped at least 1.57 inch so you can't just do a drop of an inch with the basics?
Old Jul 29, 2007 | 12:09 AM
Calvin's Avatar
yep.
Old Jul 29, 2007 | 12:44 AM
fais's Avatar
Alright thanks
Old Jul 31, 2007 | 01:53 PM
Gsedan35's Avatar
FRONT
Height Adjust Range
Max/Min(mm/inch)
REAR
Height Adjust Range
Max/Min(mm/inch)
http://www.tein.com/infiniti.html
Looking at the site, I get
Front/Rear recommended
1.5"/.9"
Front/rear max drop (should be the minimum amount of preload)
2.6"/1.2"
Front/Rear min drop (requires a lot of front spring preload)
.7"/+.2"
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
DRG35R
Jan 31, 2016 07:14 AM
Rose M
Oct 12, 2015 10:00 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
