Best way to grease bushings on Hotchkis sways??
Old Jul 30, 2007 | 11:28 AM
rockd's Avatar
Well, I've got a bad squeak coming from the bushings on my front hotchkis sway bar (the rear seems fine, for now). What's the best way to re-grease them? Do I HAVE to take the bar off? Do you use jackstands to reach the bushings... or ramps?
And will
Valvoline DuraBlend semi-synthetic grease Valvoline DuraBlend semi-synthetic grease
work well?
Old Aug 3, 2007 | 04:32 PM
kenchan's Avatar
on my stillens and my other cars, i just remove the bracket, pull off the
bushings, regrease inside/outside, and put it back on. no need to
remove the bar from the car.
Old Aug 3, 2007 | 04:34 PM
izmir41500's Avatar
G35driver Addict
there should be a little nipple with a cap that you can use a grease gun (forgot the name of the actual tool) to regrease your bushings. i just use regular lithium grease that comes in a white tube at sears.
see the red caps in the pic. my hotchkis brackets have black ones.
Old Aug 3, 2007 | 04:41 PM
kenchan's Avatar
that's a nice idea they used...
but on the other hand, they shouldve put collars from the getgo. lol
griotsgarage has some nice needles you
can use to grease through those holes.
izmir41500's Avatar
G35driver Addict
i got collars on mine
Old Aug 3, 2007 | 06:33 PM
rockd's Avatar
only the rear has those nipples... the front hotchkis bushings don't come with them.
I figured out that I was able to reach under the car and spray silicone onto all 4 bushings (without having to lift the car)... this stopped the squeaking for about a week. Today, I sprayed the silicone and spread a heavy layer of grease around the bushings... hopefully, it'll last longer.
Old Aug 3, 2007 | 07:39 PM
DHCrocks's Avatar
silicon spray wont work, it's too thin and will wash out too easily. A thicker grease will hold up a lot better.
Old Aug 3, 2007 | 10:41 PM
THX723's Avatar
G Kreuzer
Yes silicone spray will actually "clean" the grease off of the bushings. The surest way is to disassemble them, re-grease generously, re-install, and wipe off excess around the bushings. You don't want sand to collect around them.
Use heavy duty water proof grease.
Old Aug 4, 2007 | 09:00 AM
zpeedray's Avatar
I use marine grease, i remove the front brackets, one first, then the other one, about the rears the have the "grease points" so it easier. I do this to my sways and it last for about 6 to 8 months. Daily driven.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
