Installing Tein Basics and Rear Camber Arms
Old Aug 14, 2007 | 01:59 PM
hoolamonster's Avatar
Should I DIY this I hear its some what a pain. I called a shop here in PHX and the guy wanted 400$ for install and alignment (this was a recommended shop)...
Old Aug 14, 2007 | 02:34 PM
redlude97's Avatar
Installing coilovers IMO is very simple and easier to install than springs. The hardest part is usually the front since you need a spring compressor, but not so with coilovers so it should relatively straight forward. You can install the rear camber arms at the same time too so it doesn't take that much longer. If you have toe bolts to install also, have a dremel with a high speed cutting bit ready, but other than that its DIY
Old Aug 14, 2007 | 03:38 PM
GreenGoblin's Avatar
The goblin resurrection
yes it is very easy as redlude said but it also depends on how mechanical and what tools u have. will need jack, stands, at least a ratchet set and wrenches.
Old Aug 16, 2007 | 09:31 AM
cc1012's Avatar
Air Toolsss
Old Aug 16, 2007 | 09:47 AM
izmir41500's Avatar
G35driver Addict
I plan on using this guide:
http://www.350z-tech.com/zwiki/Rear_...d_Installation
here is the front:
http://www.350z-tech.com/zwiki/Front...d_Installation
I need to find a way to get ahold of a jack and stands and you can borrow a torque wrench from autozone.
Old Aug 16, 2007 | 09:51 AM
Hi-TechG35's Avatar
You've got two good guides. I'd DIY and just pay for the alignment. It's realy not that hard providing you have the right tools, some liquid wrench and patience.
Old Aug 16, 2007 | 09:52 AM
izmir41500's Avatar
G35driver Addict
looks like i need power/air tools. it seems like it would be hard to get the bolts in the rear...hmmm anyone do this with regular wrench and sockets?
Old Aug 16, 2007 | 01:13 PM
redlude97's Avatar
the rear is super easy to do without power tools, thats how I did mine.
Old Aug 16, 2007 | 01:17 PM
cc1012's Avatar
i guess it depends how old your car is. If your cars got some miles on it you might want to consider power tools.
Old Aug 16, 2007 | 05:35 PM
izmir41500's Avatar
G35driver Addict
i can't seem to find any instructions on how to do the rear. drifsu1 had a diy but one of the pics don't work. can anyone takes some pics so i can grow some cahones to do the rears? seems like it would be super easy, but i just need some pics.
also how do you adjust the height. i was reading teins instructions bit didn't help without pics. i'm a visual learner as you all can tell.
Here's an install: http://g35nyc.com/forums/showthread.php?t=470
I posted in the suspension DIY thread also.
So for the basics in the rear, the spring does not go over the shock correct? They retain the stock locations of shock and spring.
Old Aug 17, 2007 | 03:03 PM
Autozone it is!
Old Aug 22, 2007 | 02:51 PM
ckrug03's Avatar
Originally Posted by izmir41500
let us know how it goes. i may needs some tips for the rear install.
I installed m tein basic's and camber kits in my garage. Air tools helped but were not needed. The rear install is simple it should only take 15 to 20 minutes per side. The front was a little tricky, took 30 to 45 per side. Good luck.
teamghost
Jul 28, 2015 04:52 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
netcbc
Jul 24, 2015 11:25 AM
beevanhuynh
Jul 23, 2015 01:37 AM
