New rotors
Old Aug 15, 2007 | 05:00 AM
ILuvMyG35's Avatar
Cool New rotors
Has anyone came across this before?
I have installed new front rotors, slotted ones.. DBA 4000.
Now it looks funny because the brake pads don't cover all the area of the rotors (only the outer circle are contact). The inner circle area is untouch.
I looked at my neighbor's Maxima.. they have bigger pads..
I wonder if I can use Maxima's pads?
Attached Thumbnails New rotors-dscf1900-small-.jpg   New rotors-dscf1901-small-.jpg   New rotors-dscf1902-small-.jpg   New rotors-dscf1903-small-.jpg
Old Aug 15, 2007 | 05:03 AM
ILuvMyG35's Avatar
Not to mention now my braking performance has decreased compare to stock rotors.. Now I can't make the ABS turn on when I floor my brake pedal. I think I use to be able to do that before..
I only had the new rotors for 400 km.. maybe hasn't bedded in?
Old Aug 15, 2007 | 05:09 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
Everything looks fine to me, even on BBK's the pads dont cover the entire surface area of the rotors. What break in procedure did you use for the brakes?
-GP-
Old Aug 15, 2007 | 05:37 AM
ILuvMyG35's Avatar
My Break-in procedure was not to do any hard brakes during the first 300-400 miles. I am only on 150miles right now.
But I did hard brake once just to test if I install everything properly. This is the first time I change the rotors on my own. I hope that one time didn't warp my rotors.
What do you suggest?
-GP-
Old Aug 15, 2007 | 05:45 AM
Find a wide open space of road with no stop signs/lights
10 runs at 60-10 (hard braking), speed back up to 60 immediately after each run. Avoid coming to a full stop at all costs. After the 10 runs drive the car on the freeway for 10-15 minutes avoiding any major braking to let the brakes cool down. Park the car and let it cool all the way down (til the brakes are cool to the touch). Your pads/rotors should be fully bedded.
-GP-
Old Aug 15, 2007 | 06:05 AM
ILuvMyG35's Avatar
Do you mean 60-10 km/h? I live in Canada..
If you mean 60-10miles/h that is like 100km/h - 15km/h..?DOMO
-GP-
Old Aug 15, 2007 | 02:29 PM
Dan_K's Avatar
Yup.
http://www.stoptech.com/tech_info/wp_bedinstock.shtml
Old Aug 18, 2007 | 12:18 AM
DaddysG35's Avatar
You are not supposed to contact the inner-hub ring, next to the hub, where it is attached to the rotor (the outer rim). Pound on the brakes hard a couple times on a back road to get the bite into the rotor and level off the pads. Maybe go for a flex-stainless line kit. My 2 cents.
Old Aug 22, 2007 | 01:11 AM
Jaffy5150's Avatar
I have the same rotors (DBA 4000) and also hate the discoloration where the pads don't touch the rotors. I agree that the stopping power seems less than OE. I even replaced my stock lines to SS. What pads are you using?
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
nanobotking
Oct 8, 2015 08:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
