Are e-bay wheel spacers any good?
these are the ones I got
http://cgi.ebay.com/ebaymotors/20mm-...spagenameZWDVW
Not installed and I don't have any other spacers to compare them to so that's why I can't say if they're good or bad yet.
on
Should have got the bolt on type for your stock wheels, MUCH easier to install
Originally Posted by G35Asian
True, but do you want your whole wheel assembly to rely on a spacer? My friend had the bolt on type and it ended up snapping while he was driving . Had to get new suspension parts for that corner and body work done. He also had the good brand (H&R). Stick with spacers with extended studs.
from what i noticed, anything 20mm or less uses the longer bolts and the larger spacers (25mm and up) use the attached studs.
I'm dropping the car on S-Techs and I'm thinking about going 15mm in the front and 20 in the back with stock 19" rays. I don't know if 20/25 would be too aggressive and cause rubbing. I'm running 275/30/19 tires on the rear and 245/30/19 on the front so there is a bit more rubber bulging out compared to the stock 245/35/19 and 225/35/19.
what do you guys think of that setup?
personally i think its all about torque. Some people over-torque their wheel lugs like crazy, it's no wonder they sheer right off.
I'm going to go ahead and order the e-bay wheel spacers, see what happens.
Thanks for what input I got.
