rattle after swapping coilovers out -- HELP!!
Old Aug 28, 2007 | 02:34 PM
cturnbull802's Avatar
i just swapped in some tein htech rear springs, in place of my buddy club coilovers. i have a rattle sounds like its coming from the rear deck drivers side. i checked to make sure every all the bolts i touched were tight. i even re-torqued the 12mm's that hold the oem shock in. any ideas? is there supposed to be a rubber gasket on top of the shock?
Old Aug 28, 2007 | 02:40 PM
617G's Avatar
CFW (Carbon Fiber Whore)
there's a rubber piece that sits on top of the spring
Old Aug 28, 2007 | 02:42 PM
yes i know its huge...
Old Aug 28, 2007 | 02:43 PM
and present on both side.
there is also a rubber piece on the bottom of both springs.
but it sounds like its coming from higher up on the car.
Old Aug 28, 2007 | 05:18 PM
erdog's Avatar
Make sure the bolt right on top of the mount, under the dampener adjustment **** is tight. That was my problem that caused my rattle. If you have a coupe, that might be a pain to get to. If you have a sedan with rear reclining seats, then its easy to get to.
Old Aug 29, 2007 | 12:50 AM
its a coupe... and not that bad. i will have an update tomorrow, as i just got home from work and dont feel like tearing into my car @ 1am
Old Aug 29, 2007 | 11:58 AM
i am so pissed off right now... i jack my car up and am looking for this rattle... and low and behold my wheel / brake rotor are wobbling around. i am like wtf did i not tighten the lugs? nope they are tight. my drivers side wheel bearing is blown out. this is seriously the biggest piece of **** car i have ever owned.
50k miles = Brake master cyl springs a leak. i end up replacing pads, rotors trying to figure it out...
52k miles the power door lock drivers side works when it wants to.. i normally have to use my key to unlock my car.
57k miles wheel bearing is toast.
i bought the car with 40k miles on it thinking i was buying a reliable low mileage car.
</rant>
Old Aug 29, 2007 | 01:19 PM
the actual noise was the rear brake rotor coming in contact with the dust shield slightly. it would hit and make a TING TING TING noise.. so i bent the dust shield back. however i have a much more serious problem being that my wheel bearing is completely shot. i do not have another car to drive and work almost 30 min away, so i guess ima drive it till the wheel falls off, or this weekend whichever comes 1st
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
doakley92
Sep 25, 2015 12:58 PM
