Best Brakes for the Money?
Old Aug 29, 2007 | 02:16 PM
Omistry's Avatar
Hey I was wondering if anyone knows where I can get a cheep set of brakes, which is an improvement over my OEM 2004 brakes. I have to get it replaced soon, and I am just starting to do the research on brakes.
Thanks
Old Aug 29, 2007 | 04:58 PM
fortified's Avatar
Thanks
Non-Brembo? The OEM have been improved over the original 03-04 pads. They are pretty good actually, You could probably get them cheaper online than from a dealer.
If you go over to www.tirerack.com you will find a complete line of different and reasonably priced pads, with the best and worst features of both.
http://www.tirerack.com/brakes/resul...ance+Wheel+Pkg
Old Aug 30, 2007 | 03:24 AM
my05g35sedan's Avatar
well
I just replaced all four rotors & pads with cross drilled & slotted zinc plated and low dust pads from raceconcepts on ebay and I was blown away by the quailty all for $225 shipped. Now I have the brake feel & performance the car should have had when I bought it with only 24K miles on it. I had a spongy pedal that reacted different every time you pushed it, now it's rock solid and the same every time. Look em up, sometimes more expensive is not better.
Old Aug 30, 2007 | 12:17 PM
fortified's Avatar
You mean this place? looks decent. Let us know how it all holds up with cold bite, fade, noise, and dust as you rack up the miles.
http://www.r1concepts.com/
Old Aug 30, 2007 | 02:15 PM
Triple8Sol's Avatar
OEM Brembos imo.
Old Aug 30, 2007 | 03:39 PM
fortified's Avatar
But converting non-Brembo to Brembo is definitely not cheap!
Old Aug 30, 2007 | 08:16 PM
Omistry's Avatar
I was thinking about making the conversation from non-Brem to Brem, but when I found out how much it costs, I was like I will have to do it later. Right now, I am just looking for something that will be better then the OEM non-Brem.
Thanks a lot guys for the suggestions. I might try the R1. Do I need to change the brake lines or should I wait for another time?
Old Aug 30, 2007 | 10:06 PM
ttrank's Avatar
Grocery getter
Best high performance bang for the buck is the Racing Brake 13" 1-pc 4 piston front kit and their 13" oem caliper rear kit. They also give a discount to the G35Driver members.
If you can get a set of oem brembos it would be even better but those go for 1,800-2k used and you can get the RB kit for less.
Old Aug 30, 2007 | 11:58 PM
absolutg's Avatar
workin...
does that RB kit fit newer sedans? i thought it was only for 03/04?
Old Aug 31, 2007 | 12:15 AM
Fortified - yes thats the place, they hooked me up. I drive a stock motor on the street and have no use for a 3K$ brake system. I doubt 90% of those that have them have that much use for them either.
Old Aug 31, 2007 | 12:22 AM
ttrank's Avatar
Grocery getter
The front 4 piston kit will fit all sedans and the rear oem caliper kit will fit all the sedans. The oem caliper kit will not fit the 05+ sedan front.
Old Aug 31, 2007 | 12:49 AM
bocatrip's Avatar
I too have an 04 non brembo with the notorious dust making short life squealing 0EM pads. I replaced them 2 months ago with Akebono Pro Acts and wow.....what a difference. The brake dust is about the same or less than the OEM rear pads, no more squealing, even in reverse and very linear stopping while needing only slightly more pedal pressure than the OEMs. I wish I replaced the OEM pads 4 years ago. The ceramics are also much easier on the rotors.
Old Aug 31, 2007 | 01:00 AM
absolutg's Avatar
workin...
Originally Posted by ttrank
The front 4 piston kit will fit all sedans and the rear oem caliper kit will fit all the sedans. The oem caliper kit will not fit the 05+ sedans.
wait i'm confused by your second statement
Old Aug 31, 2007 | 01:11 AM
HipHopPro's Avatar
If you go with r1 Concepts Rotors, the "FREE Zinc to Prevent Rusting" is only good for "ONE WEEK" then it's back to the rusting
Old Aug 31, 2007 | 01:14 AM
nate4598's Avatar
Do you have their website? or where to order them?
Thanks
Nate
