Rims Question !!!!!
Old Sep 13, 2007 | 05:50 PM
awong's Avatar
Exclamation Rims Question !!!!!
Does anyone know if the coupe 19" sport pkg rims will fit into a sedan with doing anything to the suspension or change anything. My #1 concern is that im scare it might rub so if anyone can give me any information bout that ... it would be great thanks
Old Sep 13, 2007 | 10:00 PM
Beebo's Avatar
should fit
Old Sep 15, 2007 | 10:09 PM
TheIvoryG's Avatar
They definitely do fit...at least on the 2007. I just put them on and they fit perfectly. It needs a bit of a drop though as the front runs just a bit high.
Old Sep 15, 2007 | 10:17 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
They will fit any sedan. If you're lowered, you might have a chance of rubbing. It wont rub much if it does at all (if you're lowered) if it does rub, then you can either do a mild fender roll or you can increase your negative camber by 1/2 of a degree and you'll be all set.
-GP-
Old Sep 16, 2007 | 01:28 AM
g-spot26's Avatar
They will definitely fit but you are going to need to change the tire size and aspect ratio. This is a handy little tool that can help you keep the speedometer and ride height as close to factory as possible: http://www.1010tires.com/TireSizeCal...?action=submit
http:www.tirerack.com also has some recommendations. I was thinking about going to 20'' on my )7' but the sidewall would be a full inch smaller than the 18in rims that came from factory. Think, sport suspension, stiff sidewalls, might feel like getting kicked in the back over each bump.
Old Sep 17, 2007 | 02:15 PM
awong's Avatar
-GP-
Im not planning on lowering it but i just keep it stock and hopefully it wont rub at all when i just put it on thanks
Old Sep 17, 2007 | 02:16 PM
awong's Avatar
ill give it a try when i get my rims and hopefully it work like you said it would
Old Sep 19, 2007 | 11:17 PM
The-Dream's Avatar
Pretty confusing, since we have staggered wheels.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
hurleyguys
18 Inch
Sep 9, 2015 12:24 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
EasySausage
Jul 14, 2015 11:17 PM
