Anyone using 235/35/19 and 255/35/19 for their stock 19?
I am picking up a set of new tires and thinking about putting 235/35/19 and 255/35/19 for OEM 19. Anyone has that set up? I am not lowered, so will the 35 sidewall make the wheel gap larger? Thx
When compared to stock:
On the front, the sidewall will be less by 0.3 in, and circumference will be less by 2 inches. The speedometer will also be 2.3% too fast.
On the rear, the sidewall will be less by 0.4 in, and circumference will be less by 2.1 inches. The speedometer will also be 2.6% too fast.
Lou
Come on, pony up for the 245/35/19 fronts and 275/35/19 rear.
Everyone will tell you that your tires will fly off sending your car into a fiery crash off a mountain and the tire manufacture will deny liability leaving your grieving widow and orphaned children penniless.
Ignore the pontificators and forum experts. I am running this setup on my stock 19's (with 15mm spacers, yes I live on the edge) and have had no problems. And I run my car pretty hard around the twisties.
Originally Posted by lowrider
I'm usually the one posting about not putting too wide a tire on a narrow wheel, but for your wheel widths (8" in front and 8.5" in rear) 245/35/19 and 265/35/19 should work OK, and match up well with stock wheel ODs. I realize that 265 is out of manufacturer's specs for an 8.5" wheel, but it should fit and not have significant sidewall bulge. I would NOT go any wider though.
Lou
Lou
Originally Posted by Klubbheads
Im running 255/30/19 -rear and 235/35/19 -front toyos. It sits perfect. My next set is going to be 265/35/19 and 245/40/19 r/f without having that bulky look.
^the stock tire is 225/40/19 and 245/40/19 in the back. I hated the way it looked the front ones looked very good but the back ones were ugly. For some reason it seemed that the back tire was 50 series tire compare to the front one. With my setup that i mentioned on previous post it looks ok eventhough the car is dropped on coupe s-techs the wheels look kinda small from close up. It might be because mine is a sedan but I think the size that i mentioned would look perfect with toyos.
so why not go 245/35/19 and 265/30/19? Those would have approximetly the same sidewall, without making the front tire too tall. A 245/35/19 will look like a 225/40/19 from the side as far as sidewall height is concerned.
seagrasser
May 3, 2022 09:43 AM
FS[MidWest]: MINT Gramlights 57's pro's with titanium lip
doublej32
19 Inch
Jan 28, 2016 08:42 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Tonka211
Sep 18, 2015 09:46 AM
